Rough idle??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-10-2013, 11:13 AM Thread Starter
Rough idle???
So I'm still new to the diesel world but I bought my 2008 f250 xlt about 10 months ago. All that I have done to it is put a 6" lift with 35" toyos and a dpf delete with a h&s xlt pro tuner on a mild tune currently. I recently just did another oil change and all my filter changes and the truck seems to still be having a rough idle at a cold start and even after warm up. It seems to get a lill better after warm up. This is what I found after I did my filter change and cleaned everything out in my lower fuel filter. What are your all's opinions and what else should I do to the truck to keep it running smooth?
grimreaper is offline
post #2 of 6 Old 06-10-2013, 12:09 PM
05_PSD_Erik's Avatar
I would keep a close eye on your filters and start running some good fuel system cleaner. The best cleaner is biodiesel, if you can find any local to you. If you do find some biodiesel local and run it, keep a spare set of fuel filters in the truck as the bio REALLY cleans things out and can clog your filters up pretty quick.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #3 of 6 Old 06-10-2013, 02:07 PM Thread Starter
Do you know if biodiesel with effect my tune on the truck with the h&s tuner?
post #4 of 6 Old 06-11-2013, 03:44 PM Thread Starter
To the top
post #5 of 6 Old 06-12-2013, 03:13 AM
It won't affect anything as long as you have a DPF delete.
Jon5212 is offline
post #6 of 6 Old 06-12-2013, 04:13 AM
Also, get some Sea Foam.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
