6.4l with 6.0l issue - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-06-2013, 10:22 AM Thread Starter
Well I thought I would ask this if I still had my 03 F-350, which is still issue free. But my 08 F-450 what I think is a blown head gasket needs a new motor at 108k miles! Ford doesn't seem to want to help, so does anyone know if a 7.3l will go into this truck? if so what needs to be done?
Jim
jmaly is offline
post #2 of 22 Old 06-06-2013, 06:36 PM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #3 of 22 Old 06-06-2013, 06:38 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 275 Post(s)
well does it need a head gasket or a motor?
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #4 of 22 Old 06-07-2013, 06:16 AM Thread Starter
It's still at the dealer so I have not got into the motor myself nor has ford. The oil is contaminated with water it was using 2-3 gallons of water a day, but the oil was not over full. They are telling me the best way to fix it is a new motor for $17k. I have a 99 7.3l that runs great I was thinking of putting in it.
I have also seen people use a 5.9l Cummings, does anyone know if the cab has to be removed to install this motor?
Jim
jmaly is offline
post #5 of 22 Old 06-07-2013, 06:29 AM
Quoted: 275 Post(s)
If its out of warranty get it out of that dealership and find a good diesel mechanic near you. I cracked a piston in mine and I know if I would have taken it to a dealership they would have insisted on installing a new motor. Instead I took it to an independent shop and they replaced only what needed to be replaced and I was out 5 grand instead of 17
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #6 of 22 Old 06-07-2013, 06:31 AM
ZMANN's Avatar
Quoted: 1462 Post(s)
the cummins swap is easier since there are companies that make all the adapters for the motor trans etc and standalone controllers for the tranny
the 7.3 would be an emissions violation and not a common swap si I imagine it would be a biotch
I would just find a low mile 6.4 or fix what issue yours may have unless it's a block
We Miss you Ronnie
ZMANN is offline
post #7 of 22 Old 06-07-2013, 06:38 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Sounds like someone is being duped.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #8 of 22 Old 06-07-2013, 07:09 AM Thread Starter
Thanks guys, I had it to the dealer to see if Ford would step up since it has only 108k miles. I plan on getting it out and I'm looking at options as I need my truck for hauling my equipment, the 99 works ok till I get 15K lbs behind it.
Jim
jmaly is offline
post #9 of 22 Old 06-07-2013, 07:47 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Get a pressure guage setup on the degas bottle. If you have bad HGs, you will see pressure rise in coolant system when you hammer on the skinny pedal. If you dont see that, thats not your issue.
post #10 of 22 Old 06-07-2013, 07:51 AM
Quoted: 275 Post(s)
Head gaskets normally don't contaminate the oil. It sounds more like an EGR related issue but you still could have bad head gaskets.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
