turbo hiss - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-01-2013, 12:16 PM Thread Starter
turbo hiss
hello i recently am noticing a hiss that sounds like air being let out of the tire while engine is running. i can hear it in and outside the cab. my up pipes look to be in good shape and no soot showing. i smell no fumes either. it is comming from that general area though. can somthing wrong with the turbos cause this noise? i have no power loss and boost seems ok. how can i trouble shoot to find the problem?
Zacfrd is offline
post #2 of 17 Old 06-01-2013, 01:03 PM
Powerstroke Techie
The gasket between the two turbochargers, maybe?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 17 Old 06-01-2013, 06:48 PM Thread Starter
s there a way to check for leaks in the turbo system?
Zacfrd is offline
post #4 of 17 Old 06-02-2013, 09:15 AM Thread Starter
will these leaks that cause the hissing cause any damage?
Zacfrd is offline
post #5 of 17 Old 06-02-2013, 04:46 PM Thread Starter
anyone have any ideas or know if it will cause damage?
Zacfrd is offline
post #6 of 17 Old 06-02-2013, 09:56 PM
F450Harley's Avatar
Is the hissing sound there at all times, when truck is running.......or it only does it when its cold, then it stops as it gets worm ?
Title on hand like always
F450Harley is offline
post #7 of 17 Old 06-03-2013, 07:30 AM Thread Starter
t is there all the time and rises with rpm. sounds like letting air out of a tire
Zacfrd is offline
post #8 of 17 Old 06-03-2013, 10:06 AM Thread Starter
k this thing is driving me crazy. if I dont see soot around the up pipe what is another way I can check to see if it is leaking? I have a mini max tunner. would my exaust back pressure change if there is a leak? I wish there was a way to run smoke through the motor and see where it comes out. any ideas?
Zacfrd is offline
post #9 of 17 Old 06-03-2013, 02:01 PM
F450Harley's Avatar
Yeah man. That would drive anyone up a wall.
The best way to get closer to the noise is, get a stethoscope & listen to it . Hopefully that will pin point your problem. Good luck to you
post #10 of 17 Old 06-04-2013, 09:53 AM Thread Starter
ok used a stethoscope and could not pin point it. i did remove a wire from the exhaust that would go to egr cooler which i have removed and when the actuator on the turbo shut the hissing stops??????
Zacfrd is offline
