Help!! Boost/power problems. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-14-2013, 08:26 AM Thread Starter
Hey fellas, I am having powerloss while pulling around 8000lb. Trailer, thing is I am only getting around 15-20psi if boost. Not sure what is going on. It will be running fine, on cruise, then all of a sudden fall on its face and won't go passed sixty. And now, my engine light is on??? Also, I have noticed a oil leak under the engine but oil level is still good in truck. Ps. I am on the road in the middle of nowhere between Odessa and San Antonio, no position to for computer, shop, or much else. Just have some sockets. Is this any problem I can do while I mm out here? Should I keep driving like this???
codyhorn is offline
post #2 of 2 Old 05-21-2013, 12:45 PM
mine was doing that and it was the MAP sensor... it was getting full of carbon/gunk and not reading the pressure properly. Dealer replaced sensor and pigtail and the problem went away, then it came back a while later and I pulled the sensor and cleaned it with carb cleaner and it fixed it...
2008 F250 CC SWB KR
35/12.50/20 Toyo M/T's, chrome Hostage 20x10's, 4" Zone lift w/ control arms in front, 5" newton block with Fat Boy traction bars and 2" pro comp add a leafs in rear, Top Gun dual stabilizer, Bushwacker flares PTM, AFE Magnum Force stage 2 si intake, H&S mini maxx, Mbrp exhaust 4" turbo to tip w/ wrapped downpipe, LP Batmowheel, Sinister egr delete w/ elbow, Arp studs, Dark Horse diesel CCV to exhaust, Turbo Blankets, Roll N Lock, Husky Weatherbeaters, Optima Red tops...
MID-CON is offline
