Truck won't start - Ford Powerstroke Diesel Forum
post #1 of 20 Old 05-11-2013, 01:56 PM Thread Starter
BMF_Powerstroke's Avatar
Truck won't start
I have a 2010 F-350. I got in it today to drive. The truck turns over but won't start. I kept turning it until my battery was near drained. Charged it back up and still nothing. All fluid levels are good. I just drove the truck 3 days ago with no issues. I'm pretty savvy on gasoline motors but not diesel. I could use some help here. Thanks in advance.
6" Rough Country lift w/ Bilstein 5100's, 37" Toyo M/T's, 18" M19 Rims, Volant Intake, H&S Turbo-Back Racing Exhaust with DPF Delete and Mini-Max Programmer, Amp Power Steps, Road Armor front and rear Bumpers, 12k lbs Smitty winch, Recon Smoked lights all around, Factory Nav Unit with JL Audio C5 series Component speakers on 350/4 Amp, JL Audio 13.5TW Stealth box on 500/1 Amp and train horns.
BMF_Powerstroke is offline
post #2 of 20 Old 05-11-2013, 02:58 PM
BlackSheep5's Avatar
Codes?
Sent from AutoGuide.com App
08 F250 6.4L FX4
BlackSheep5 is offline
post #3 of 20 Old 05-11-2013, 05:28 PM Thread Starter
Originally Posted by BlackSheep5 View Post
Codes?
There are no fault indications. Should I run diagnostics anyway?
post #4 of 20 Old 05-11-2013, 05:48 PM
ramonpowerstroker's Avatar
Yes you should, did you simply run out of fuel? Did you change the fuel filters? Did you do absolutely anything to the truck? Maybe bad fuel conditioner? Maybe a bad fuse? Check all connections, what mods do you have on the truck?
ramonpowerstroker is offline
post #5 of 20 Old 05-11-2013, 05:58 PM Thread Starter
On second look, I ran diagnostics and I have a P0090 code (fuel pressure regulator 1 control circuit). I cleared it, still won't start. I have no idea what to look at here. Any help?
post #6 of 20 Old 05-12-2013, 05:30 AM
Prob the high pressure pump harness. Had a few trucks just up and not start with that code and it was that.
08 F250 6.4L FX4
post #7 of 20 Old 05-12-2013, 06:21 AM Thread Starter
I didn't do anything to the truck. I installed fog lights on Wednesday then drove it around for a few minutes. Parked it and went to drive it yesterday....now it won't start. I have a full tank. All of my mods are listed in my signature. I'll check fuses. I read some where that a blown FRP fuse can do this...
The Following User Says Thank You to BMF_Powerstroke For This Useful Post:
6.4_Piper (05-22-2017)
post #8 of 20 Old 05-12-2013, 07:37 AM Thread Starter
No blown fuses. After clearing the P0090 code, it came back right away. Still no start. Not even a kick with holding the gas pedal in. What's next?
post #9 of 20 Old 05-12-2013, 07:45 AM
PowerStrokeEnginuities's Avatar
Check frp and see what your pressures are, need a scan tool to watch pids on.
size="5">KEEP STROKIN
IF YOU DONT STAND BEHIND OUR TROOPS, FEEL FREE TO STAND IN FRONT OF THEM.
Proud U.S. Marine VET!
PowerStrokeEnginuities is offline
post #10 of 20 Old 06-05-2013, 04:43 AM Thread Starter
So, last time my truck did this, it started up all of a sudden after about 4 days. It's doing it again though. Same exact symptoms. I'm changing the fuel filters in hopes that's all it is. But, would that necessarily throw a FPR code?
