Turbo boost leak? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-23-2013, 05:34 PM Thread Starter
2008f250twinturbo's Avatar
Turbo boost leak?
Hey guys, when driving my pickup it sounds like theres a turbo leak somewhere more towards the driver side. It only seems to do it when theres more than 20psi of boost. It has seemed to be performing somewhat poorly in the past few weeks. I visually checked over the turbos today and didnt notice anything. Any ideas where the leak could be coming from? or if it could be something else? thanks!
2008f250twinturbo is offline
post #2 of 18 Old 04-24-2013, 03:16 AM
BlackSheep5's Avatar
First check your piping boots
Sent from AutoGuide.com App
08 F250 6.4L FX4
BlackSheep5 is offline
post #3 of 18 Old 04-24-2013, 06:14 AM Thread Starter
like the boots going to the innercooler?
post #4 of 18 Old 04-24-2013, 06:15 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yes check the boots for the intercooler pipes. ALso check the up pipes and the firewall for soot.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 18 Old 04-24-2013, 06:53 AM Thread Starter
Okay thanks! hows the best way to check for small cracks?
post #6 of 18 Old 04-24-2013, 07:11 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I guess the best way would be too see if some oil seepage is leaking out of the boots. Might be worth taking them off and cleaning them. I did that a couple of weeks ago.
08 F350 cc/sb 4X4
post #7 of 18 Old 04-24-2013, 08:45 AM
Check those Up-Pipes. How many miles on your rig? Are you tuned or stock? How much boost can you pull WOT?
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #8 of 18 Old 04-24-2013, 02:16 PM Thread Starter
Its got 104k, tuned with a mild tune for the dpf delete. can build about 39psi of boost wide open
post #9 of 18 Old 04-24-2013, 02:18 PM Thread Starter
also it has a raspy sound without much power when engine is cold, any ideas what that could be? thanks!
post #10 of 18 Old 04-24-2013, 03:56 PM
Gotcha. Well, form what you are saying....I agree with the others about checking the intercooler boots. However, I'm betting on the up-pipes. The up-pipes take a ton of abuse when the 6.4 is stock and regens on a regular basis. Trucks that are deleted early in life and have avoided the brutal heat cycle of regens tend to get more life out of stock up-pipes. However, they can fail at any time stock or not. Look for soot and check those boots. Oh by the way 39PSI is good depending on your tune...check those up-pipes.
