Truck going into limp mode. Code P0088 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-23-2013, 06:37 AM Thread Starter
A week ago after pulling away from a traffic light my truck lost power but stayed running. It also threw code P0088. The outside temp was close to 90. I stopped, turned the truck off then restarted and drove off. This cycle happened 4 more times. If I was able to get the truck up to speed the problem went away. Also, when the temp dropped below 75 the problem went away. I've driven the truck 300 miles since the last incident without an issue. The outside temp has been 60-75 degrees. Yesterday my truck went into limp mode twice before I was able to get home. The outside temp was 83.
CAI filter brand new. Changed out both fuel filters last week.
P0088 points to the hpfp. If the pump is bad why would the truck work flawlessly in cooler temps yet have issues when it warms up outside? Do higher external temps have anything to do with this issue and are simply a coincidence? Could a bad or dirty MAF be a cause of this issue? Bad fuel?
Looking for your thoughts on what the issue could be. Temps here in Houston are beginning to rise so I'm anxious to get a resolution.
2015 F250 Lariat SD FX4
6" Rough Country Lift
20" XD Series Wheels
37" Nitto Trail Grapler M/T
Stock
2008 F250 Super Duty 4X4
6" Pro Comp Lift
Pro Comp 6001 Wheels
Nitto 37" Terra Graplers
4" dpf/cat delete w/MBRP
SCT Tuner - Performance Tune
bsudkamp is offline
post #2 of 13 Old 04-23-2013, 06:47 AM
Quoted: 2 Post(s)
I'd be leary of the lift pump before the hpfp. Time to open the fuel supply and check flow and pressure. Could be a clogged filter, etc.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #3 of 13 Old 04-23-2013, 08:47 AM Thread Starter
Thanks.
Where does the lift pump reside? Which pump supplies diesel at idle and initial acceleration? The truck runs great once I get to speed. The initial start is when I run into problems.
Stock
6" Pro Comp Lift
bsudkamp is offline
post #4 of 13 Old 05-15-2013, 07:37 PM
Same symptoms on my 2008 at 131K. Turned out was HPFP.
Ford has a TSB on this issue the HPFP P/N has been updated to a rev B part.
I have the 200K extended diesel care warranty. Ford sent a rep to my dealer to check fuel system then approved HPFP cab off replacement.
TSB
11-4-22 6.4L - LACKS POWER - DTC P0088
Publication Date: April 27, 2011
FORD: 2008-2010 F-250, F-350, F-450, F-550
This article supersedes TSB 11-4-15 to update the Service Labor Time Standards.
ISSUE:
Some F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine may exhibit a lack of power concern with an intermittent diagnostic trouble code (DTC) P0088; at full operating temperature during moderate to heavy acceleration.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Intermittent P0088 diagnostics:
Check all continues memory DTCs. Is DTC P0088 the only code present?
No - do not continue with this procedure. Refer to the Powertrain Control/Emission Diagnostics (PC/ED) to diagnose this concern.
Yes - continue to Step 2
Replace the high pressure pump (HPP). Refer to Workshop Manual (WSM), Section 303-04C for HPP replacement.
Both the fuel volume control valve (VCV) and fuel pressure control valve (PCV) adaptive learning parameters must be reset after a HPP replacement. Refer to PC/ED, Section 4, Hard Start/No Start Diagnostic Subroutines step 7 to reset adaptive tables.
PART NUMBER PART NAME
8C3Z-9A543-B High Pressure Fuel Pump
OTHER APPLICABLE ARTICLES:
10-20-10
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110422A 2008-2010 F-Super Duty 6.4L Regular Cab: Check DTCs And Replace the HPP Includes Time For Prior Approval, Remove And Install Cab, And Reset Both VCV And PCV Adaptive Learning (Do Not Use with Any Other Labor Operation Except For Other Applicable TSB Articles) 8.9 Hrs.
110422A 2008-2010 F-Super Duty 6.4L Super And Crew Cab: Check DTCs And Replace the HPP Includes Time For Prior Approval, Remove And Install Cab, And Reset Both VCV And PCV Adaptive Learning (Do Not Use with Any Other Labor Operation Except For Other Applicable TSB Articles) 9.1 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9A543 42
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
post #5 of 13 Old 05-19-2013, 03:28 PM
Powerstroke Techie
That TSB has been superseded. It's now a reflash to correct this concern.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #6 of 13 Old 06-03-2013, 03:37 PM
I am having the same problem. Truck acts up when its hot and throws the P0088 code.
Super excited to pay big bucks to have the HPFP replaced. I am thinking I should try the reflash to fix first. Is it TSB (is it 12-7-7 ?) before spending the $'s on the replacment.
Anyone had success with it?
yukonsc is offline
post #7 of 13 Old 06-03-2013, 05:39 PM
Here is the TSB
TSB
12-7-7
6.4L - LACK OF POWER - DIAGNOSTIC TROUBLE CODE (DTC) P0088
Publication Date: July 17, 2012[/color]
FORD:
This article supersedes TSB 11-4-22 to update the Service Procedure. ISSUE:
Some F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine may exhibit a lack of power concern with an intermittent DTC P0088; at full operating temperature during moderate to heavy acceleration. A calibration update is available to resolve this concern.
ACTION:
SERVICE PROCEDURE
Check all continuous memory DTCs. Is DTC P0088 the only code present?
No - this article does not apply, refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual to diagnose this concern.
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 79.05 and higher. This new calibration is not included in the VCM 2012.5 DVD. Calibration files may also be obtained at Buy Motorcraft Parts Online | Official Motorcraft Auto Parts Site | FordParts.com.
__________________
Max2006 is offline
post #8 of 13 Old 06-03-2013, 05:43 PM Thread Starter
P0088
Update to my issue. I have an SCT Extreme. A month back I loaded the tow tune. If I don't punch it when pulling away from a light I have no issues. Additionally, once I go through the 4th trans shift (40 plus mph) I can lean on the pedal more without issues.
When I do lose power, the fuel rail pressure is still over 10000 psi according to my Edge Insight.
My question is what exactly does this high pressure pump do? Once I get to speed (45 mph plus) I can accelerate w/o issues. Could we be experiencing issues with the lift pump?
Stock
6" Pro Comp Lift
bsudkamp is offline
post #9 of 13 Old 06-03-2013, 05:45 PM Thread Starter
HPP
A quick question. Any idea on what the cost would be for an HPP replacement outside of warranty?
Stock
6" Pro Comp Lift
bsudkamp is offline
post #10 of 13 Old 07-20-2013, 04:57 AM
Jonboywv12's Avatar
Send a message via AIM to Jonboywv12
Great Im glad to hear all of this, left early this morning to head to work drove 10 miles or so at 60mph no issues got onto some of the back roads 35-45ish mph no issues got down to where i was going slow but just turning into the parking lot BOOM! limp mode wont do anything over 2,000 rpms i turned around went back up the road and i can just very lightly hit the pedal and it will get up to speed but even then it wants to hesitate, not noticing any smoke or any of that coolant levels seem fine oil is good. i turned it off and i restarted it then my check engine light appeard. waiting on my brother so i can use his programmer and pull code. thank goodness this truck is still under warrenty going from what yall have said and my problem...is it going to be a hpfp or lift pump? THanks guys!!
Jonathan or Jon
2002 F-350
4" Banks turbo back exhaust.w/5" tip
4" Banks down pipe
Banks Big Hoss turbo waste gate
6" SKY JACKER
35" Nitto All-Terrains
TW chip 6 pos.
Banks Trans-Command shift kit
AFE STAGE II Intake
Gauges (boost, EGT)
102" whip antenna (guaranteed 100hp!
enough for fun!
Jonboywv12 is offline
