re assm 6.4 crank spacer???? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-20-2013, 02:33 PM Thread Starter
Need to know how to position the spacer that the rear main seal rides on.there is a dowel hole for it but no dowel pin in the crank?I know that it has to be postioned correctly since the flex plate has a counter balance on it.Any help?? thanks Stan
ruslow is offline
post #2 of 11 Old 04-20-2013, 02:56 PM
dowel pin on spacer goes towards the flywheel. fly wheel goes on one way.
2003 F350 7.3L Lariat FX4
05-07 badges
05-07 front conversion
casserly stage 2 165cc injectors
srp1.1 hpop
gtp38r (should've done h2e
custom 6 position chip
isspro ev2 gauges
6inch lift
4inch Straight Pipe
Mt's 37x13.50 R20
3.73 gears
billet converter
48 gallon fuel tank
08 Front and Rear Axles
plus more.....
soon to come: bts trans.
swalker332 is offline
post #3 of 11 Old 04-20-2013, 04:30 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
if you're talking about the flexplate adapter you're not supposed to remove that. It is machined true after it is bolted to the crankshaft.
It's there because the engine, being of international origin, would not use the same flexplate/flywheel in a medium duty application.
I understand that this adapter is in the way of removing the camshaft, unfortunately for 6.0s and 6.4s the crank must be lowered before removing the camshaft.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 11 Old 04-20-2013, 06:30 PM Thread Starter
I realize that now.But what if you need to replace the crank gear then what?ford does sell new bolts[torque to yield] so it can be serviced.What do you do if you need to replace the crank gear?i just need to know the relationship between the carnk gear keyway and the dowel hole in the spacer.then all will be fine.Thanks Stan
ruslow is offline
post #5 of 11 Old 04-22-2013, 05:43 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
couldn't tell you. I know for sure there's no procedure in the manual for anything you describe
-Matt
2015 F-250 XLT 6.7L
post #6 of 11 Old 04-22-2013, 06:15 PM
Powerstroke Techie
That's an incorrect statement, sir.
Originally Posted by Ford Workshop Manual
NOTICE: To prevent engine damage, do not remove the rear primary crankshaft flange bolts under any circumstances. If the flange is removed and reinstalled, it will result in engine vibration and premature transmission component wear.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #7 of 11 Old 12-06-2013, 10:48 PM
6.4 crankshaft adapter
So what did you figure out? I have the same problem on a motor I rebuilt.
Ambulance39 is offline
post #8 of 11 Old 12-07-2013, 12:02 AM
there is hole drilled on the flex plate adaptor to index 180* from the crank shaft gear alignment pin.
the only way to make sure its correct is to make sure that dowel hole on the fp adaptor is directly 180* from the pin that holds the crank gear in place
08 F350 Green/tan
ThcGunSmoke is offline
post #9 of 11 Old 12-07-2013, 04:25 AM
Yes but has someone done this procedure and has it worked out ok for them. Or do they have a continuous vibration.
post #10 of 11 Old 12-07-2013, 08:17 AM
truck had bad vibration. the flex plate adaptor was installed wrong by someone due to the crankshaft not having a dowel hole to index
looking at an prevoius shortblock the cranks dowel hole was drilled 180* from the pin that holds the crank gear inplace realigned and problem solved
08 F350 Green/tan
