Could it be my HPFP? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-12-2013, 01:50 PM Thread Starter
JrStroker285's Avatar
Okay, so here goes. I have a 08 job 3 F250, spartan tuned 210LL with a 4 inch straight pipe. My truck has been acting up here lately, Throwing a P0088 code Fuel rail/system pressure-to high. It seems like this is a Pretty common code here in the 6.4 forums, well before I go and drop that fat stack of cash that I dont have on a new HPFP, I'd like a little closure first. Maybe, it isnt it.
So my truck has the normal symptoms of bucking and jumping after you hit the throttle hard. My Mustang before did the exact same thing, and it was the fuel pump. The truck acts fine while its still sorta cold, even after it hits operating temp its fine for about 15-20 minutes, then it starts acting up. It seems to only do it on warmer days too, around 50+ degrees. There seems to be a whine/groan coming from the back of the motor in-between the firewall.Sounds like its coming directly behind the 4x4 knob and about 12-18 inches above the floor board. in that general area. It only starts when I'm in the throttle and fuel rail pressure is around 11000+/- 1000 and will continue to 18000+.
So my fuel rail pressure is said to be "high" but here are the general pressures
Idle- 5050-5100
1/4 throttle - 8000-9000
1/2 throttle - 13000-15000
3/4 throttle 22000-23000+
I havent had time to replace to sensor yet.
I replaced my fuel filters around 300-400 miles ago.
I just drained my water separator, seemed to hesitate and gargleing sounds came before a drip of water and a steady stream of fuel.
One of my main questions is, if it is the pump going bad, can and will it grenade itself and ruin the fuel system/injectors? How long could this thing last with the symptoms? I'm assuming it will get worse but in what amount of time? I'm doing some cab off things here in about 2 months, can it wait till then?
I feel like I put a decent amount of information. Any help or advice would be greatly appreciated. Thanks guys and gals!
__________________
Some of this, some of that
Custom sound system
JrStroker285 is offline
post #2 of 4 Old 04-15-2013, 06:34 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I can not answer your question as i am not sure. What are you going to be pulling the cab for in 2 months?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 07-02-2013, 09:29 AM
Stroken49s's Avatar
Ever figure it out, have a buddy having the same problem, like you, he is never getting over 25000 PSI but the code keeps popping up
Tim S. MISSISSIPPI GULF COAST
2000 F250 w/ 28.5 CHASE N HOOKERS LIFT
SOLD: 2008 F350 King Ranch CC/LWB Dually, SPARTANIZED DPF DELETE, AFE STAGE II
SOLD: 2006 F250 XLT CCSWB FX4 w/ 6" Lift on 37" BFGs
SOLD: 2008 F250 Lariat CCSWB 4X4 Stock W/Spartan DPF Delete & AFE
Originally Posted by Moto2four View Post
"if my aunt had nuts she would be my uncle."
Stroken49s is offline
post #4 of 4 Old 07-20-2013, 04:03 AM
Jonboywv12's Avatar
Send a message via AIM to Jonboywv12
any insight on what it maybe or what it was? my truck is doing the exact samething right now happened this morning!!
Jonathan or Jon
2002 F-350
4" Banks turbo back exhaust.w/5" tip
4" Banks down pipe
Banks Big Hoss turbo waste gate
6" SKY JACKER
35" Nitto All-Terrains
TW chip 6 pos.
Banks Trans-Command shift kit
AFE STAGE II Intake
Gauges (boost, EGT)
102" whip antenna (guaranteed 100hp!
enough for fun!
Jonboywv12 is offline
