Bad diesel?????? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-10-2013, 03:39 PM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
pumped gas instead of diesel.......HELP!!!!!!!!!
Can bad diesel make your truck have a hard time starting. Have 08 f450 with Dpf delete and egr off they mini max. Everything has Been fine for months. Just did oil change last week at 56k mikes. Now today pump gas and it took like 3 attempts and giving it some gas to get he to start. What could it be. How much should I drain from the diesel water separator?
Update......help please
So my son put premium unleaded instead of diesel.........WTF. The station by our house has green label for premium unleaded and that's what he put. I'm so pist I could @"$)(;:*^%#}{_\~€ŁĄ•. More so I'm post at myself. I should have not let him.
Anyways what now. I drained the tank. Put half tank with 20 oz of diesel kleen. Started up and no strange noises. He only drove about 7-10 miles.
Redz284u is offline
post #2 of 5 Old 04-10-2013, 04:49 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
run some diesel kleen through it and see if that helps... Did you let the wts light to go out?
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 5 Old 04-10-2013, 09:27 PM
F450Harley's Avatar
Aaagh... man. Sorry that happened .You need to run that truck on freeway (high speeds) for a good number of miles , while keeping a close eye on the tail pipe. Hopefully there wont be any puffs of white smoke or any backfiring . If you see or hear any of that then you got a problem. You better off have it checked.
F450Harley is offline
post #4 of 5 Old 04-11-2013, 05:06 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
Heavy foot or just normal. Is the purpose to wash out injectors by lots of heavy volume or slow but constant flow?
Redz284u is offline
post #5 of 5 Old 04-11-2013, 09:48 PM
F450Harley's Avatar
No.....Dont be hard on it . Just normal driving. You should keep the engine 2000-2400 rpm though.
