6.4 Compression Problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-08-2013, 06:54 PM Thread Starter
ok 2008 6.4 with 89,000 miles. Took it to the mechanic and was told low on compression after a compression test. Ended up changing all pistons, rings, rods and everything in the engine. When I got truck back and now 11000 miles into my 12000 mile warranty I had compression checked again and nothing changed after i dropped 7000 into all that work. Now I am being told that the fuel injectors in the pistons that were showing low compression in the first place need to be changed. Im struggling with putting more money into fuel injectors or if the compression problem can be something else. Need to get an answer before warranty is up. So he is telling me that with a bad injector in those pistons I could have hurt the new rings already in 3 months causing same low compression figures in same bad cylinders. Seems fishy please help!
jlauck22 is offline
The Following 2 Users Say Thank You to jlauck22 For This Useful Post:
williehood (03-25-2016)
post #2 of 4 Old 04-09-2013, 05:30 PM
WEWILLE's Avatar
What were the compression numbers? Why were you having compression checked anyway? I'm assuming the engine misfires or runs poorly... Injectors will not affect compression...
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #3 of 4 Old 04-09-2013, 06:10 PM Thread Starter
Truck never ran rough or anything. Heard a knocking noise out of ordinary so took it to the dealer. They diagnosed a lifter rod. So i took it to a different mechanic I was told about. He used his pc for a compression test and cylinder 2 was at 7% cylinder 4 at 5% and cylinder 8 at 4%. Then he told me i needed to replace those pistons. Once he had it all apart he said cylinder walls were fine justshould change all rings and pistons and rods while he was there. So all of that was changed and then I needed a hydroboost fixed the other day so while I was at dealer I asked him to do tests on it since my warranty was almost up. He found all the same values on same cylinders so nothin was different. So took it to guywho did the work and he said cylinder 2 and 4 need new injectors. He also said compression wont get better with new injectors they just wont get worse. so at this point im 7000 in for no reason. Ford mechanics say its something with piston rings not seeding right after his work. What do you think
jlauck22 is offline
post #4 of 4 Old 04-10-2013, 03:19 AM
WEWILLE's Avatar
Wow, let's start from the beginning. What type of knocking noise was it. Did you hear it at idle only? Load, or all the time? Dealer claimed it was a push rod or lifter? Why didn't you have dealer replace the push rod? What it sounds like the other guy did was just a relative compression test. It's a good test, by I would never tear an engine apart based on a relative compression test. plus if compression was that low I would suspect some sort of drive ability concern. Replacing injectors will not improve a base engine concern, neither will injector replacement prevent a base engine concern from getting worse unless an injector is doing damage to the cylinder. How many miles are on the engine? I hate to say it, but this sounds like a bad deal for you.
2011 Ford Edge
WEWILLE is offline
