08 no start - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-07-2013, 01:33 PM Thread Starter
350 ONE TON's Avatar
08 no start
Have an 08 350 spartan tuner Dpf and egr delete. Ran fine since the tuner has been in an started fine. Now it sat overnight ad no start. Turn the key wait for the WTS light to go out turn key and nothing. No click no crank. Checked fuses and relays all seem to be fine. Even tried the spare key thinking something with PATS. Any ideas??
2003 F250 XLT 6Spd 4X4 ECLB 4" lift 4" turbo back duals, AFE Stage 2 XP, superchips flashpaq (gone soon I hope) GTP38R, Gutted EBPV
350 ONE TON is offline
post #2 of 14 Old 04-07-2013, 04:11 PM
jpag06's Avatar
Are your batteries good? Had the same problem a while back and I had a bad battery good luck
jpag06 is offline
post #3 of 14 Old 04-07-2013, 05:47 PM Thread Starter
Yep batteries are good. After searching online I think the conclusion is an EGR temp sensor. Anyone know if this will keep the truck from starting? If so where is it located
post #4 of 14 Old 04-07-2013, 05:48 PM
6.4PSD's Avatar
Subscribed
2008 F250 CCSB
Gearhead Hot Street
No limit intake and Cold Side Pipe
EGR Delete
CCV Mod
5" Flo Pro
Ranch Hand
35" Nittos
Texas A&M Construction Science
6.4PSD is offline
post #5 of 14 Old 04-07-2013, 06:08 PM Thread Starter
This is my stepdads truck so ill keep updated as this unfolds
post #6 of 14 Old 04-08-2013, 07:29 AM Thread Starter
Update. Unhooked all the EGT sensors in the delete pipe and truck starts. I think the plan is to leave them unhooked after talking to spartan they aren't needed after the initial tune install
post #7 of 14 Old 04-08-2013, 06:47 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Glad you got it figured out!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #8 of 14 Old 07-03-2013, 04:56 AM
tonsofduty's Avatar
I have same issue, but have a Minimaxx with full delete. I also have a no bung exhaust. No start, security light flashing, batteries good, OBD 2 locked out. Where is this sensor just in case mine shorted out after I deleted?
tonsofduty is offline
post #9 of 14 Old 07-03-2013, 05:09 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
Subscribed. Good trick to know just in case.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #10 of 14 Old 07-03-2013, 10:16 AM Thread Starter
If you mean where is the EGT sensor, there is 3 of them in the exhaust. Or since you have a no bung pipe they may be zip tied up along the frame. They are right about where the cab and bed meet on the frame for a reference point. Hope that helps. If not let me know ill try to be more specific!
