6.4 help - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-06-2013, 01:22 PM Thread Starter
lvillelightning's Avatar
6.4 help
08 f250 180,000 miles coming in from work a few ago it started running bad ..its smoking and missing see some oil leaking from drivers side ...my H&S shows 3 codes PO284 cyl 8 contribution/balance ..PO263 cyl 1 contribution/balance and PO308 cly 8 mis fire ...any ideas what is my problem guys ...
lvillelightning is offline
post #2 of 14 Old 04-07-2013, 06:13 PM Thread Starter
also has lots of pressure and blow by on the oil filler cap when you remove it
post #3 of 14 Old 04-09-2013, 05:35 PM
WEWILLE's Avatar
Is oil level overfull?
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #4 of 14 Old 04-09-2013, 06:34 PM Thread Starter
no its not
post #5 of 14 Old 04-10-2013, 03:24 AM
WEWILLE's Avatar
It sounds to me like an injector is most likely bad. I'd run relative compression test at minimum. Then I would ensure the injector harness is not chaffed anywhere especially around fuel filter bowl area. Do you have a decent scan tool that can do relative compression, power balance testing, and the standard ford tests? If not your most likely going to have to take it somewhere.
2011 Ford Edge
WEWILLE is offline
post #6 of 14 Old 04-11-2013, 08:48 PM Thread Starter
i dont have any of the tools its at the shop now ..not sure till he pulls it down but some test run this evening showed #8 cly down 14%
post #7 of 14 Old 04-16-2013, 08:11 PM Thread Starter
cracked #8 piston
post #8 of 14 Old 04-16-2013, 08:16 PM
ramonpowerstroker's Avatar
Crap bud sorry to here that, I'm getting scared about doing injectors to make sure this don't happen
ramonpowerstroker is offline
post #9 of 14 Old 04-17-2013, 03:20 PM
'086.4LDiEsEl''s Avatar
Quoted: 2 Post(s)
Im at shy of 180,000. Ivillelightning, were there any symptoms prior to experiencing the smoking and missing?
'086.4LDiEsEl' is offline
post #10 of 14 Old 04-17-2013, 03:43 PM Thread Starter
No symptoms at all just left a stop sign and it started missing and running bad
