Blueish smoke - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-24-2013, 05:31 PM Thread Starter
Blueish smoke
Truck was running fine. Then I installed a coolent filter and a CCV mod and driving home the truck is puking a bluish smoke. Temps and coolest temp is fine power was all the same it was just puke out smoke. Could it be that I didn't disconnect the battery when I unhooked the maf senser and I need to reload my tune? Any ideas please it's my daily driver
rogco is offline
post #2 of 6 Old 03-24-2013, 06:46 PM Thread Starter
So reloaded tune. Took it for a drive and truck seemed to smoke when the bigger wheel started to spool up and when I let go of the gas it just dumps out and smells like oil.
rogco is offline
post #3 of 6 Old 03-25-2013, 12:31 PM
Quoted: 2 Post(s)
i'm assuming you're tuned and deleted? what color is the smoke? does it do it in when its hot or when its cold. is your coolant level going down? is your oil level going down?
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #4 of 6 Old 03-25-2013, 12:36 PM Thread Starter
I havent driven it enough to check levels. Yes dpf deleted. And smoke about the same warm or not. Its a light blue smoke and smells like something is burning like oil. Going tomorrow to shop to get them to do a coolent test to see if its the head or not
rogco is offline
post #5 of 6 Old 03-25-2013, 01:25 PM Thread Starter
I let the truck run for a bit this morning and theres oil running out of tail pipe
rogco is offline
post #6 of 6 Old 03-25-2013, 01:26 PM
Quoted: 2 Post(s)
I'm pretty sure from reading the forums for some time now that oil out the tail pipe usually means blown turbo seals. You have a serious issue. Try a search.
Kris
