- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
White Smoke
I have had my truck for maybe a month now and this is the 4th time this has happened. The truck idles up to around 1100 RPM like it is going into Regen, but it stays there until I shut the motor down, because the idle never drops (8-10 minutes). During this high RPM idle, white smoke starts to blow up from underneath the front 2 doors of the truck and from the engine compartment. If I dont close the A/C recirculation button, the cab fills with white smoke. This smoke is not coming from the exhaust tip. After the first time, I took it to Ford and they reflashed the computer. It did the same thing and I took it back. They kept it for days and drove it with a laptop hooked up to it and said everything was perfect (which I dont doubt at the time). This is an intermittent problem. I am taking it back to Ford this week again. Does anyone have any idea as to what this might be? I assume it's something with the Regen process, but obviously something is malfunctioning. Thanks in advance for any input!
Frank |
| Sponsored Links |
one thing to know , is if you do not let it finish doing an regen then its gonna continue to try to do one , if it continues to build up it will smoke pretty bad ,as far as smoke from under cab , you may want to tell them you think you have an exhaust leak, i havent seen it much yet , but there is a bulletin about the clamp on the turbo and gasket replacement for something similiar to what you are talking about,
Thanks
sounds like a exuast leak right after the turbo
| Sponsored Links |
