New here, & need help, ton of white smoke & power loss & stall - Ford Powerstroke Diesel Forum
Old 03-02-2013, 08:20 AM
Yesterday my truck started blowing a ton of white smoke, lost power, was chugging and died, started up again but not running well at all, drove it straight to ford about 2 blocks, they said it could be EGR pump? I was looking on line at EGR delete kits??? any thoughts would be great!!
Old 03-02-2013, 08:56 AM
Are you loosing any coolant?
Old 03-02-2013, 09:05 AM
yes, a little
Old 03-02-2013, 10:51 AM
Chances are that you EGR cooler is ruptured then. Does it constantly smoke? Does it smell like coolant from the exhaust?
Old 03-02-2013, 11:44 AM
Yes, and yes
Old 03-02-2013, 11:48 AM
What about the EGR delet kit?
Old 03-02-2013, 12:26 PM
You could get an EGR delete kit but you'll also need a tuner and a dpf delete as well. I don't think the EGR can be deleted without also deleting the dpf. Unless there are certain tunes I'm unaware of.
Old 03-02-2013, 12:35 PM
Thanks for the info. Just trying to figure out if thats what I should do? How often do the EGR pumps go? I like my truck and plan on keeping it for a long while, any other things that I might need to keep an eye on or change?
Old 03-02-2013, 01:14 PM
There's no pump. It's just a valve and a couple coolers. The failures aren't as common as the 6litre but they do happen. Deleting the dpf and EGR systems are a good idea if you plan on keeping it for a long time. Most of the issues arise from these 2 components with fuel system issues up there as well. Draining the water separator at least monthly and using good quality fuel are very important as well.
Old 03-02-2013, 01:17 PM
Forgot to mention the cooling system. If you plan on keeping the ford gold coolant then make sure you monitor the nitrate levels. I believe they have to be above 800ppm to work properly. Otherwise flush and put in a nitrate free ec-1 rated coolant.
