stuck in regen - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-26-2013, 05:18 PM Thread Starter
stuck in regen
08 f450 with 130k city driven. No codes. Been stuck in regen on and.off the last few weeks...not its stuck permanently. Getting about 5.5-6mpg. Could it be the filter is finally clogged and time for removal? Also when I was parked by a snow bank the snow turned green by the exhaust.
2008 F450 w/Century 311. DPF/EGR delete. Spartan tuned.
2003 Grand Marquis..some mods...
jasong145 is offline
post #2 of 6 Old 02-26-2013, 05:55 PM
Quoted: 48 Post(s)
it could be clogged or it could be cracked... rare for a 6.4 filter to crack
you could pull it and clean it thoroughly at a coin-op car wash
drunk on diesel is offline
post #3 of 6 Old 02-26-2013, 05:59 PM
Powerstroke Tech
whitestrikr21's Avatar
Quoted: 3 Post(s)
Garage
stuck in regen
I've also seen the cat not getting hot enough and constantly causing it to smoke and go into regen all the time. Cat was replaced no more issues. Didn't set any codes, passed high pressure pump leak test aswell.
03 F-350 Crew Cab short bed
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
Silverline staintless turbo back 4"
XDP egr delete
whitestrikr21 is offline
post #4 of 6 Old 02-26-2013, 05:59 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
dpf may be clogged up, get codes pulled and have good diag run on truck, even if check engine light isnt on may be codes in memory to help pinpoint issue
ITS STOCK
SCUFFY828 is offline
post #5 of 6 Old 03-01-2013, 07:10 AM Thread Starter
After being stuck in the mode for lil over a week..went on the highway with my car in tow and it got out of it.
Im in cleaning mode again...lets see how long it lasts this time...i hate living in the city..frequent cleaning modes and not enough thorough clenses
post #6 of 6 Old 03-01-2013, 01:27 PM
Powerstroke Tech
Quoted: 3 Post(s)
Garage
stuck in regen
You can also put it into manual regen using a ford Ids and you don't need to drive it just let it idle
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
XDP egr delete
