Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Motor Problems
Old 12-06-2007, 07:13 PM
bajasst bajasst is offline
CHECK ENGINE LIGHT
Got a check engine light this morning on the way to work. Truck operates fine though. Called and have a appointment tuesday to find out what is up. Anybody else had the light go on before?
Old 12-18-2007, 07:03 PM
Sayonara Sayonara is offline
mine came on this weekend on a trip to Northern MI. i read the manual, checked the gas cap and filled up. after 3 stop/starts it cleared. i think it was either a lose gas cap or a botched start. i short started it and it didnt turn over. needed 2 more attempts top start. ill keep an eye on it but no other problems and it ran fine.
Old 12-18-2007, 07:10 PM
Mine ended up being a cracked engine shroud of some sort. Not sure what yet. Part just got in and being replaced tomorrow.
Old 12-19-2007, 11:25 AM
TwinTurboStroker TwinTurboStroker is offline
Now, on to the race truck
A crack engine shroud set off your CEL?
Old 12-19-2007, 11:39 AM
That's what they are telling me. I thought that seemed odd also. How would the computer know that. Should be picking it up in a couple of hours. The light was on for a couple of days and then I did a system check and it went away.
Old 12-19-2007, 12:00 PM
Rude86 Rude86 is offline
I had a C/E mistery light for 2 days, filled up and after 200 miles it was gone
Old 03-02-2008, 07:53 PM
Been Around Been Around is offline
Got an engine light with a good-running engine, and the dealer said that a sensor was sending unexpected signals, which by default pops the light. Not error signals, but signals the computer doesn't know what to do with. It's apparently a known issue and isn't a defective sensor per se. It's more of a programming problem to work around an unhappy surprise in the sensor design. So I was told to disregard (sort of) if it reappears UNLESS the engine is presenting some odd behavior. They will reflash it with a fix when it's available.
Old 03-02-2008, 07:54 PM
redstroker_2002 redstroker_2002 is offline
KVFD
r u pullin any codes??
Old 03-03-2008, 03:43 PM
Redstroker,
If you're asking me, no. No codes, no equipment, no knowledge. All I have is a checkbook.
