Another high boost - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-05-2013, 06:53 AM Thread Starter
Another high boost
I read the other thread but I am not running H&S or Spartan tunes and I am in San Diego so no cold weather like the other guys, so I thought a different thread would make sense.
I didn't drive my truck for a week or so (I was cruising around with my big block 454ss!). On my way to work, I watched the boost go to 30-40 under 25% throttle and at 2000-2500 rpms. I don't feel like there is a power loss, but I am used to the big block with no turbo. It may just be that I haven't driven this truck, but that seems high. I checked the boots and they are connected and I couldn't feel any holes or suction with my fingers.
Is this normal or is something going on?
ryano2121 is offline
post #2 of 8 Old 02-05-2013, 06:55 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I still would remove and clean your map and ebp sensors. It doesnt have to be cold for those to cause problems.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 8 Old 02-05-2013, 06:59 AM Thread Starter
Ok. I knew my 6.0 inside and out but the 6.4 is new to me.
Is the map sensor on the air intake?
Where is the ebp sensor?
How do I clean?
post #4 of 8 Old 02-05-2013, 07:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Check out the pictures i posted in this thread.
Loss boost, turbo sensor code
08 F350 cc/sb 4X4
post #5 of 8 Old 02-05-2013, 07:08 AM Thread Starter
Ok, I see them all now. Just unscrew and clean with brake kleen?
post #6 of 8 Old 02-05-2013, 07:09 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea thats what i did. Although i ended up replacing them because they are not that expensive.
08 F350 cc/sb 4X4
post #7 of 8 Old 02-05-2013, 03:00 PM Thread Starter
That seemed to do the trick. Thanks!
post #8 of 8 Old 02-06-2013, 08:21 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Good deal!
08 F350 cc/sb 4X4
