- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
2008 F250/350 Radiator Bulletin
I'm not a tech so I can't post this in the tech section, but admin and mods please feel free to repost there.....
402000 - Engine Cooling Systems Concerns 20063-2008 F-Superduty - 6.4L Engine - May exhibit coolant leaks located at the radiator side tank crimping area. Some 2008 F-Superduty vehicles equipped with a 6.4L diesel engine may exhibit coolant leaks at the radiator side tank crimping area. All service parts with a build date of 8/6/2007 or later are certified stock. Before installing service parts with a build date prior to 8/6/2007 visually inspect to ensure that end tank crimp tabs are completely closed and no cracks are present at the trans cooler line fittings or inlet/outlet ports. Build dates are located on a yellow or white label located on the top radiator cross rail. After the radiator is removed from it's packageing inspect to verify there is no damage present that may result in a leak or repeat repair. Note: Black lateral lines on the radiator are a normal result of the manufacturing process. Radiators are fully functional and should not be rejected due to this discoloration. I also have a couple other bulletin that they gave me about overheating, valve cover removal, fuel pump noise, heater core noise and loss of power, if you want me to post those as well |
| Sponsored Links |
overheating
My '08 is on it's third radiator, last one lasted less than 1000 miles, I hope the new ones are better. Good luck.
| Sponsored Links |
