Something doesnt seem right.
First off I have An 08' F-250 6.4 A/T with 92K miles on it, completely stock. This has only happen maybe 3 times in the past 6 months so I'm not too worried about it but just want to make sure it's not going to turn into anything serious. Is whats happening is when I take off from a stop and just accelerate normal (shifting around 2k) and when I go to get on it a little more (like a car is coming up quick behind me) it starts to studder a little and lose some power. I look in the passenger side mirror and notice a little bit of blueish/whiteish colored smoke. If I let off the skinny pedal a little bit and get back in it, it doesnt do it anymore. I'm not throwing a CEL or anything of that sort. I keep a close eye on the coolant and it has used a little bit within the last 4 months (~3/4 quart). I dont know if my EGR cooler is leaking a little bit and causing it to do this or an injector is F'd up. I try to mimic the scenario and see if I can get it to do it again but I cant. Only does it when she feels like it. But like I said its only done it 3 times in the past 6 months.
What do you guys think it could be? Any and all input would be greatly appreciated guys!! Thank you. |
Condensation in the intercooler
Thanks for the help. So whats the protocol to fix that? New intercooler?
There is a TSB and a revised intercooler design. I'd get it to the dealer ASAP and hopefully you're still under warranty and can get the revised design.
It's only happened to me twice. I have the revised design, but if I cruise around long enough under the right temperature/humidity conditions, it'll happen. When I did thermostats, I drilled/tapped the bottom point of the cooler and was going to put a solenoid valve on it to be able to drain it on command, but it hasn't been an issue again. It happened to me during the summer in south east TX |
not sure there
Ok well thanks for the help and the input! Glad I'm not the only one. Thought I was going nuts. I'll look into the warranty and getting the revised version. If not I'll get an aftermarket one and update the plumbing. Thanks for your help drunk on diesel
FW Spin, I actually just noticed this same issue this morning when driving mine. I was getting onto the free way and the truck was stutter stepping, and wouldn't pick up and go very easily and then I noticed in the rear view that I had a bunch of blueish/white smoke dumping out the back. And then I'd let off and it the smoke would go away but the hesitation in application of power seemed off.
Did you get a chance to try any fixes on this particular issue yet? Thanks, John |
Well fellas I have the same exact thing. Posted in a different thread this morning. The dealer had told me last week to try to figure out when it was doing it and there was a TSB that fixes the condensation issue but it needs to be over 40 deg and high humidity. Not the case here in Iowa this time of year. I figured out when she would do it, when it comes up to temp and would last 3 minutes or so. Just got off the phone with my guy at the dealership and it is in regin mode. Which sounds right but no dash indication. So for the last week it has been smoking at least once a day due to this, also has not finished the regin cycle. This may be due to the TSB 11b23(reflash) as it has been reported to disable the dash indicator. I am definetly leaning towards a delete after all my research today. The whole DPF deal scare the crap out of my down the road.
