Normal Fuel PSI? - Ford Powerstroke Diesel Forum
Old 12-14-2012, 08:11 AM
Normal Fuel PSI?
Since replacing that low pressure fuel pump yesterday I am going to keep my fuel PSI gauge on the mini maxx.
What is normal at idle? Cruising speed?
I notice that when I am coasting down a hill, it is at 0. Cruise set at 67 it is about 9.2.
Old 12-14-2012, 09:49 AM
i see 4.8 at idle and at wot i see about 24.5
Are you talking about ICP on the minimaxx?
Old 12-14-2012, 09:57 AM
I have the ICP displayed. Is that not my fuel pressure? If not, which one is?
Old 12-14-2012, 09:58 AM
the ICP one is the rail pressure i believe. The other one is injector pulse width. The rail pressure (ICP) is the one you want to monitor.
Old 12-14-2012, 10:07 AM
So I should see 4.8 at idle and what is WOT?
I guess mine seems extremely low then at 67mph???
Old 12-14-2012, 10:09 AM
I see 4.8 at idle. WOT i believe most tuners command 24.5.
Old 12-14-2012, 10:11 AM
OK. I need to check mine at idle then.
Sorry for the ignorance but what do you mean by "WOT", and what do you mean most tuners command 24.5??
Old 12-14-2012, 10:13 AM
WOT is wide open throttle. When you put the skinny pedal to the floor if you are maintaining railpressure you should see around 24.5
Old 12-14-2012, 10:15 AM
If you are cruising around 67 mph 9.2 seems about right. I will keep an eye on mine around 70 mph and report back to you. That sounds about right tho
