Truck Stalled and Won't Start P0087 and P0232 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-12-2012, 11:16 AM Thread Starter
barlowchiro's Avatar
The first issue, I was driving down the insterstate 30 miles from home, cruise set at 65mph and the truck just dies. I coasted to the end of the exit ramp. Tried to start it and it wouldn't even turn over. After about 20 min it turned over and on the next try it finally fired up. Drove for 3 days and it did fine. Second issue, driving to work, 3 miles from my house with the cruise set at 58mph and the truck just dies. Coasted into a parking lot and the truck would turn over but wouldn't fire. After about 10 minutes, it wouldn't even turn over anymore. Had it towed to a mechanic and he couldn't find anything wrong with it. Let it sit and idle, he drove it around with no issues. I brought it home and my mini maxx gave me 3 codes: P0578 Cruise Control Multi Function Input A Circuit Stuck, P0232 Fuel Pump Secondary Circuit High, P0284 Cylinder 8 Contribution/Balance. I called the mechanic back and he said his computer didn't register the P0284 Cylinder 8 Contribution/Balance code. He called back a few days later and said that if inject #8 was bad, it could be the cause of my problem. 2 weeks and $800 later, the #8 injector was replaced. I picked it up last night and it drove fine all the way home. Went out this morning and it started up just fine. I let it idle for 10 minutes or so. I drove 3 miles from my house witht the cruise set at 58mph and it just died again. It shuddered and then i pressed the gas and it acted like it was out of fuel. I coasted into a parking lot and it was still running. Pumped the gas again and it revved but again cutting out like it was running out of fuel. Then it died. Tried to start it and it wouldn't even turn over. Mini Maxx gave 2 codes: P0087 Fuel Rail/System Pressure Too Low and P0232 Fuel Pump Secondary Circuit High. I waited for 2 hours for a tow and it never would turn over during that time.
I have the Mini Maxx, CAI, 4" DP, 5" DPF delete exhause, 3" passenger side IC pipe, EGR deletes. I also have an anti-theft device (on the truck when I bought it). When you turn the key all the way forward (just short of turning it over), you have to press this little button to start the truck.
I had it towed to the dealer this morning.
2008 SB CC KR 6.4L Job 1
AFE CAI
EGR Delete
5" DPF Delete
4" DP
MBRP Passenger Side IC Pipe
H&S Mini MAXX
2.5" Ready Lift Leveling Kit
35x12.5x20 Toyo Open Country MTs w/ stock KR wheels
AMP Research Power Steps
Coming Soon: CCV Mod, Air Dog II
barlowchiro is offline
post #2 of 9 Old 12-12-2012, 11:36 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I have been reading your threads. I have no idea what it could be but i hope they figure it out and get it fixed. Good luck and keep us posted!
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 9 Old 12-13-2012, 10:51 AM Thread Starter
Ok, so the dealer called and said it is the low pressure fuel pump, $720.
I hope this fixes my problem!!!!!
I really don't want to be stranded again!!!!
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #4 of 9 Old 12-13-2012, 10:59 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
If its the low pressure fuel pump you might want to look into something like the airdog of fass. They are a little cheaper than that and you get better filtration/water seperation.
08 F350 cc/sb 4X4
post #5 of 9 Old 12-13-2012, 11:01 AM
jermcd's Avatar
$720?? geesh!
currently driving a 335i bmw, no more powerstoke
Previous powerstrokes-
2002- F250 XL 7.3 auto, 4x4
2001- F250 Lariat 7.3 auto, 4x4
2002- F350 Lariat 7.3 Dually, auto, 4x4. 141k miles
jermcd is offline
post #6 of 9 Old 12-13-2012, 11:02 AM Thread Starter
They are replacing it now. I have to have my truck and can't be without it a day longer.
That is something that I am definately looking into for future problems though.
Anyone know what would cause a low pressure fuel pump to go out???
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #7 of 9 Old 12-13-2012, 01:06 PM
BigGreen06's Avatar
Quoted: 96 Post(s)
Do you change your fuel filters religiously? Seriously, I'm not saying every 5K, but no more than 15K.
Just saying that I had my LPFP replaced a 14 months ago, because of similar issues like you were having, just cruising along, all of a sudden you have no power, you push the pedal and nothing. Mine I shut it down waited 10-15mins and it fired up again, but threw the P0087 code. At that point it had been about 20K miles since I changed the filters, I just forgot about them.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is online now
post #8 of 9 Old 12-13-2012, 02:52 PM Thread Starter
I have only had the truck 5000 miles so I don't know what the PO did. They will be changed every 10K miles for sure now though!
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #9 of 9 Old 12-14-2012, 07:43 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
THe previous owner probably didnt change the filters. THe first thing i do when i get a used truck is change every fluid and filter possible that way i know they were done.
08 F350 cc/sb 4X4
