clogged cooler or bhg? - Ford Powerstroke Diesel Forum
Old 12-03-2012, 09:26 AM
I deleted my egr coolers last week
Now my coolant has an orange film and is puking
I have burned to quarts of oil in 1000 miles
Keeps going into limp mode
But will not go into limp mode when it is cold outside
Also smoke is pouring out of oil breather
Old 12-03-2012, 09:33 AM
If there is pressure oin the cooling system and the coolers are gone its more than likely a head gasket.
Old 12-17-2012, 03:36 PM
turns out I had a clogged oil cooler. I guess it wasnt that bad because it cleared up.
at the same time i ended up having a leaking trans cooler so i had coolant and trans fluid mixing.
also thermostats were stuck open.
I had trans cooler replaced and drained trans and instaled new filter.
I used ELC coolant from local big rig shop.
Truck runs great again, no funky coolant, no puking, no temp problems.
How do people get blown head gaskets with these trucks? I dog the crap out of mine and overload it all the time. Im wondering how many people are getting screwd and just told its a BHG.
Old 12-17-2012, 05:31 PM
Powerstroke Techie
Feedback Score: 3 reviews
blown headgaskets come from the high cylinder pressures in your several hundred horsepower tunes. that's pretty much the only way to do it.
Old 01-24-2013, 12:23 PM
the truck is acting up again.
If i fill the degas bottle to the fill line, it will puke. but if i leave it low, its stays in the same and does not puke.
It goes into limp mode
all fluids are clean but the degass bottle has dirty film on the sides that looks like carbon.
clogged cooler or blown head gasket?
Old 01-24-2013, 08:16 PM
anyone? come on!
Old 01-25-2013, 04:14 AM
You are throwing codes and wrench lights right? Which DTC codes are showing up. You may have to do the "all day coolant flush." Also, you deleted the coolers but did you remove them? Did you ever have "limp mode problems before the delete? Finally, when you flashed you truck did you select EGR delete "yes"
Old 01-25-2013, 06:58 AM
What are your ECT/EOT deltas? Is it oil thats in your degas bottle? More than likely if your truck is puking its your head gaskets.
Old 01-25-2013, 06:59 AM
The way to tell if your cooler is clogged is to check your ECT/EOT deltas. We cant tell you if we dont know this info.
Old 01-25-2013, 05:52 PM
<<< 6.4 Powersmoke
If you are seeing carbon built up in the degas bottle, the EGR coolers are deleted, the thermostats have been replaced, and it is puking coolant, than I would say there is an excellent chance that your Head Gaskets are toast. I would also check compression.
