Engine Code help ???
I had these codes pop up on my H&S tuner. I cleared them all and then about 3 days later they popped up again. Are they related. Is this a common one? Is the Fan Speed Sensor Cheap? Is this the cooling fan? Are these sensors cheap or crazy expensive?
P2563 Turbocharger Boost Control Position Sensor Circuit Range/Performance P0480 Fan 1 Control Circuit P0528 Fan Speed Sensor Circuit No Signal Are these all related? |
Well i called the dealership and they were little to no help!
uh sir how could you be reading these codes LOL!!! Is there a fan speed sensor that is external to the clutch assembly? They also said there is not a TurboBoost control sensor??? |
found the problem my connector between the engine wiring harness and the clutch fan failed!!!
I had the same fan speed sensor code and I had a trans sensor code come up at the same time. When ur fan speed sensor came on was ur fan running all the time? Mine stays on and I my trans temp gauge is not reading anything? I wonder how these two are realted or is it just a freak thing? And mine all started after I was running hard up my favorite hill, Like 30 to 90mph hard.
