Coolant in oil
I have a 2008 f450 6.4 and I just recently rebuilt the engine because it had melted a hole in a piston, after the rebuild I noticed I was loosing large amounts of coolant and discovered it was going in the crankcase. Since then we have replaced the front cover and it is still loosing coolant. I am suspecting the oil cooler , if anybody has any Ideas I am open to suggestions. Thanks Dan
Usually if its the oil cooler it will get oil in the coolant because the oil pressure is higher. Could it be leaking from the radiator or an egr cooler?
I am definitely going to check on that , but I'm not sure there is any engine oil running through the radiator. I've always seen in the past in cars that it would put the coolant into the transmission .
There is no oil running through the radiator. I would guess either a radiator, radiator hose or egr cooler. More than likely if you had a bad oil cooler you would have oil in your coolant. WHat are your deltas between your oil and coolant temp?
I couldn't tell you right now , the truck is tore down. I forgot to mention that when I rebuilt the motor , I had a new sleeve put in the cylinder that had the melted piston and I have had people tell me maybe there is something wrong with the sleeve.
Well good luck bro. Keep us posted!
Update ! After the 3rd time of having the motor out we finally figured out where the coolant is coming from. I had forgot to mention that I had put head studs in on the original rebuild , turns out that was my down fall. The studs ended up cracking my block in 4 different stud holes in the valley of the engine right above the lifters. I don't know if anyone else has had this problem or if it is just my bad luck !
I have had a lot of people ask me that , the way that I installed them is lube up the threads with the ARP assembly lube and hand tighten into the block , next I installed the head and put assembly lube on the nut and washer, then torqued the studs to 180 ft lbs in the sequence specified in the instructions and then I torqued them to 275 ft lbs. I am pretty sure that is the correct way to install them.
