Head Gastket or EGR - Ford Powerstroke Diesel Forum
Old 09-24-2012, 01:45 PM
Head Gastket or EGR
I know if I search long enough I will probably find the answer to my question but I don't have the time to search.
I have a 2008 F-350 running the hot damn 300 tune with cold air intake and 4" exhaust with all stock junk removed.
The problem I am having is if I hammer down the truck will puke coolant. I asked my dealer about it and he didn't have an answer. How can I tell if it is the head gasket blown or the EGR leaking. It only seems to do it if I hit higher boost pressures. I tried changing the cap on the degas bottle hoping it would be easy but no such luck. It first happened when I was racing my wife in her S6 (winning of course) and when I got home I realized it puked coolant. My temps never budged so it didn't get hot, it just leaked. Please tell me I can do a EGR delete and fix this problem.
All info will be greatly appreciated!
Old 09-25-2012, 12:36 AM
It could possibly be EGR or HG's so if you delete your EGR and it still pukes its probably head gaskets.
Old 09-25-2012, 06:42 AM
Its more than likely head gaskets but either way its a good idea to delete the egr. You could do that first and if it doesnt solve the problem then its the head gaskets.
Old 09-25-2012, 06:48 AM
I am thinking it is more than likely head gaskets as well. I read somewhere on here yesterday that if it is the EGR it would be blowing white smoke which it isn't doing. I hate to spend the money to do the EGR delete if it doesn't fix the problem. I also thought the head gaskets weren't an issue on the 6.4 liter PSD. I am very frustrated with this. How much does it cost to have the head gaskets replaced? And if I do the gaskets I should replace the studs as well right? I heard it was around 4 grand. That is ridiculous.
Old 09-25-2012, 06:57 AM
Mine did this Saturday night. I did a 4x4 boosted launch, left at 10psi, got it up to about 80mph and backed off. I had never done one before and I wanted to try it. No temps were real high, not sure what the boost got up to, but when I stopped and cut it off there was smoke or steam coming from under the hood. I opened it and there was coolant on everything. Not trying to hijack the thread but mine did the same thing. Sure hope its not head gaskets. Everything is fine and normal, doesnt leak fluid, and drive perfectly normal.
Old 09-25-2012, 07:13 AM
Your probably looking at around $3500-$4000 to do gaskets and studs.
Old 10-15-2012, 08:46 AM
Could be either the HG or EGR cooler, try replacing the cap to see if thats the issue its 5 bucks at advanced, if it still pukes then its HG or Coolers , do an egr Delete, if it still pukes Its HG. Dealer here quotes are around 5k . These epa emissions crap is destroing these trucks, And Ford Could give two Shyts . I think we need to start a sticky for a class action, ALL YOU HEAR ABOUT FORD IS EGR AND HG its not normal and everyone is just dashing out their hard earned $$$ to fix something that ford messed up on, as far as i hear the class action suits against ford for the 6.0 have been winning
Old 10-15-2012, 08:52 AM
PS . EGR delete quite very well make the HG issue worse since it wastegates in to the coolers.
