6.4 white smoke HELP!!!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-14-2012, 05:33 PM Thread Starter
Unhappy 6.4 white smoke HELP!!!!
My brother's was driving his truck and went for a little fun run against a duramax and as he pulled away, white smoke started coming out pretty steadily, then he pulled over and slowed down the truck now has a rough idle and white smoke all the time. We scanned it with his Minimaxx and its throwing;
*P0284 Contribution/Balance
*P0308 Cylinder 8 missfire
No cel on the gauges but definitely cannot be driven, I have 2 videos of the motor at idle, and the white smoke coming from the exhaust as well as a couple pics showing oil in intake tube and inlet of turbo and oil that is on the truck underneath/around the motor. I need help diagnosing this cause we have found anything from cracked pistons to injectors etc..
It is a 2008 f250 6.4 with dpf & egr delete with a Minimaxx and 4'' exhaust any input is appreciated, thanks!!
ID:	43076   Click image for larger version
dfwgsx is offline
post #2 of 11 Old 09-14-2012, 06:22 PM Thread Starter
UPDATE!
cleared codes and started truck for about 5 mins no white smoke, no cel. THEN cel came on and white smoke started pouring out exhaust again, spoke to Powerstroke Magic in houston and he said could be an injector then turbo seals....
IMG 2654 - YouTube
dfwgsx is offline
post #3 of 11 Old 09-15-2012, 09:21 AM
Powerage's Avatar
Quoted: 3 Post(s)
does it smell like diesel fuel or oil? Looks like a hanging injector to me.
2017 Crew Cab SB F350 Platinum with a 4" bds lift and Sota Novakanes
"It is possible to store the mind with a million facts and still be entirely uneducated." --Alec Bourne
Powerage is offline
post #4 of 11 Old 09-15-2012, 10:09 AM Thread Starter
Too me it smells more like diesel
dfwgsx is offline
post #5 of 11 Old 09-16-2012, 10:38 PM Thread Starter
how do you do remove the glow plugs on the 6.4 to do a compression test?
dfwgsx is offline
post #6 of 11 Old 04-14-2013, 07:15 PM
You sound like you have a cracked piston. Let me guess #8?
sbadave is offline
post #7 of 11 Old 04-14-2013, 10:08 PM Thread Starter
yup #8 was cracked, and the crankshaft was scarred on the journal. So had to replace 1 piston, 1 rod and new crank. finally got it back after $5500 later. crank alone was 1200 from ford house
dfwgsx is offline
post #8 of 11 Old 04-15-2013, 04:00 AM
I have one down with #8 as well cracked. Crank is fine ,my cylinder did did score my block a bit. Taking it to the machine shop today. What is causing the # 8 cylinder to crack on these motors? I'm thinking of changing all the pistons since it's down .
sbadave is offline
post #9 of 11 Old 04-15-2013, 04:12 AM
Quoted: 48 Post(s)
I would assume #8 is the most air-starved cylinder so it sees the highest EGT
drunk on diesel is offline
post #10 of 11 Old 04-16-2013, 08:48 PM
lvillelightning's Avatar
mine is down rite now 180k with number 8 cracked only thing holding it together is the rings ...kinda trying to decide on replacing 1 piston and rod or doing a short block
lvillelightning is offline
