Head gasket and studs
I want to know if it is possible to change the head gaskets and install studs without removing the cab. The reason i want to know is because i want to do the job myself and save on the labor cost but I don't have a way to lift the cab. I know that it would be very very tight under there but I am hearing that it can be done. Thanks a lot for any input!
I've heard you can do it but probably don't want to unless you have a lot of time on your hands
srjd, I noticed in your sig that you have arp studs. who did it for you and how much did it cost?
I got it done at ford. I think it was between 4000-5000 I had a bunch of other work done so I'm not sure on the break down
