Up Pipe Replacement - Ford Powerstroke Diesel Forum
Old 07-30-2012, 04:11 PM
Up Pipe Replacement
MIL came on last week so I brought it to the dealer for diagnostics. Found the right side turbo up pipe cracked, which coincides with the symptoms; exhaust smell, especially when regenerating, turbo lag and change in exhaust sound (I'm getting a second opinion tomorrow). Ford dealer wants $1600 for single pipe replacement, which includes tranny removal. Should I go ahead and replace the other pipes and the EDOC while the tranny is out, or is this a waste of money. Is there anything else I should have done while he's in there?
2008 F250 SD 6.4L PSD Lariat 4X4 CC/SRW/SB
Miles:82K
Thanks
J
Old 07-31-2012, 06:25 AM
Check out rudys diesel performance. They have a heavy duty replacement up pipe with heavy duty bellows that are stronger than the factory.
Old 07-31-2012, 07:38 AM
Looking at them now, they look good. I'm assuming that they are 6.0 up pipes remanufactured to fit the 6.4 manifold? Bolt on with the EGR port?
Item #: 64-RDP-UPPIPES $675.
or
Item #: WUPPIPES $1099......ouch for stainless....
Old 07-31-2012, 07:43 AM
ya you can get the heavy duty 6.4 up pipes or you can get the 6.0 up pipes but then you need the 6.0 exhaust manifolds.
Old 07-31-2012, 09:52 AM
Just got off the phone with Rudy's. The 64-RDP-UPPIPES for $675 are custom-built for either 6.4 or 6.0 manifolds for $599, nothing in stock. He did say they would be out the door in a day. I have the tranny out and stock pipes available today, so I'm going to replace both the pipes with stock Ford parts: 6K854*A and B. Down pipe looks fine.
Thanks for the reply
Jay
Old 07-31-2012, 10:03 AM
Just curious but how much are the stock replacements?
Old 07-31-2012, 10:40 AM
$181 a piece.
Old 08-01-2012, 08:35 AM
It's leaking just below the right bellows.
These up pipes look like they're in pretty good shape with only 80K on them. I am replacing both pipes just to be safe.
Old 08-01-2012, 11:20 AM
good thread. good luck on the install.
Old 08-02-2012, 01:05 PM
New OEM Up Pipes going in today.
