+18 SFT on #2 - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-20-2012, 01:51 PM Thread Starter
CTC DEEZUL's Avatar
Quoted: 7 Post(s)
Send a message via AIM to CTC DEEZUL
+18 SFT on #2
Truck came in, #2 contribution. Injector did not buzz. Replaced injector. Now buzzed but ran worse. Installed another injector, ran the same. Did a compression check, 430 PSI. Found faulty rockers, pushrods, bridges and lifters. Installed all new, now #2 is back to +18 on the short fuel trim.
the only thing I can think of is the cylinder is washed down and or the rings. but when I had the heads off, it looked fine, crosshatches were great...
any suggestions?
NWI Coal Rollers Assc.
CTC DEEZUL is offline
post #2 of 14 Old 07-22-2012, 05:53 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
did you actually change the lifter or see the old one? If it was damaged on the roller end assume the same damage was done to the camshaft lobe
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 14 Old 07-23-2012, 01:17 PM Thread Starter
CTC DEEZUL's Avatar
Quoted: 7 Post(s)
no, roller ends were fine, it was just the circlip that held the top portion in, so I replaced all while heads were off.
post #4 of 14 Old 07-24-2012, 05:09 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
#2 is a known hot cylinder. between it and #8 they both result in the majority of 6.4 base engine failures. Based on what you said I'd be wondering if the original injector failed in a manner that damaged the engine
you didn't happen to check the piston protrusion while the head was off? usually if a rod was tweaked you'd know it by now but maybe not.
when you cancel the #2 injector it definitely drops rpm at idle? I know you said manual compression was good but what does relative compression show?
-Matt
2015 F-250 XLT 6.7L
post #5 of 14 Old 08-20-2012, 03:06 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
haha I'm so screwed. I had to come find this thread. I've got one right now that I just put EGR coolers and a radiator in that's now running fine other than a skip on #2. Relative compression all 100%. Manual compression for that bank all showing 320psi (typical). short fuel trim is +19. Haven't pulled the valve cover yet.
Total horizontal cooler failure but it gave me no indication that it ever hydrolocked. Cranking was smooth and even.
-Matt
2015 F-250 XLT 6.7L
post #6 of 14 Old 08-20-2012, 03:08 PM Thread Starter
CTC DEEZUL's Avatar
Quoted: 7 Post(s)
I doubt its a cylinder issue. Take your fuel sample at your injector feed tube and show me the metal!!!
post #7 of 14 Old 08-20-2012, 03:26 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
is that what you found? It's been about a year since i saw any metal in the fuel
-Matt
2015 F-250 XLT 6.7L
post #8 of 14 Old 08-20-2012, 03:28 PM Thread Starter
CTC DEEZUL's Avatar
Quoted: 7 Post(s)
Not on this one, but I started taking samples and sure enough in about every 6.4 I've had pass through there was brass, and plenty of it.
post #9 of 14 Old 08-20-2012, 03:34 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
so what was wrong with the one this thread was about?
-Matt
2015 F-250 XLT 6.7L
post #10 of 14 Old 08-20-2012, 04:46 PM Thread Starter
CTC DEEZUL's Avatar
Quoted: 7 Post(s)
2bum injector... off brand. put ford one in, gone.
