6.4 turbo remove/install process???
So I have all the parts I need... This weekend I am going to attempt the impossible.. Replacing both turbos on my 6.4... Cab on... Does anyone have a full write up of this process? Or any advice??
Sent from the mower shop |
Sorry I can't answer your question but why are you replacing them and are you just putting stock ones back in?
How many miles? Mine were just replaced at the dealer they were leaking internally and blew the gaskets so I put arp studs in as well crossing my fingers I'm good to go for a while
not totally impossible but not even close to being easy. as long as you are not totally removing the up-pipes it's possible to disconnect the rear flanges and push them out of the way. You may want to fully disconnect the EGR up-pipe and move it out of the way so you can better access the rear up-pipe bolts.
Really the hardest part is probably setting the turbos back down and properly seating both oil drains at once. |
i did it about a month ago. not bad.
Pull the overflow tank off Remove fuel collant parts remove "u" shaped pipe from turbo unbolt down pipe at the top and bottom remove oil lines ontop of turbos and heat shield remove intake parts remove small bolts from "Y" pipes at rear of turbo "hard to do but is possible" remove two large bolts that hold the turbos to intake remove heavy bolts/clamps manhandle those heavy bad boys out and your done, took me and another guy 2 days having no idea what we were doing. with this help it sould not be so bad for you. only hard part it the small bolts on back of turbo for the "Y" pipe. |
Find your local Snap-On rep and purchase the 6.4 turbo socket. Its a 10MM thats elongated.... You wont have to remove the one pipe with this tool. I must warn you, I have broken 3 of these sockets in a row, so, use your torch to heat the area first. I suggest those welding sleeves and gloves to work in the area while its still hot.
just an idea
yeah my turbo socket is broken too. I dont even like it anyways, not even close to as good as the flyer made it out to be
I'll second the flame wrench too. up here every single turbo flange needs heated, I run a tap into all 6 holes too when I'm done |
the socket is amazing, you just need the right combo, snap-on 3/8 flex head extended handle, wobble extention, and the socket it self. Of course heat.
While your there, replace the oil feed line as well as he banjo bolts... They all tend to sludge up and cause this all too common turbo failure... ![]()
