Building compression in cooling system - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-26-2012, 09:09 PM Thread Starter
I have a 08 f350 4x4 spartan 275 4 inch straight pipe off turbo and s&b cold air intake. Cooling system is blowing coolant all over bottom side of my hood. I f i remove the cap to the degas bottle, it releases a ton of pressure in the system even after it has been sitting for hours of no use. Any ideas out there that would help me out? Does the spartan tuner cause this? Cant recall if this happened when the truck was completely stock. A good friend is a diesel mechanic and he says thats its not normal to build compression in the system. Need some quick responces thanks
oldschoolyamaha is offline
post #2 of 15 Old 06-27-2012, 06:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
When your cooling system builds a bunch of pressure it is more than likely the headgaskets. You can try replacing the degas bottle cap first but i dont think that is your problem. It sounds like headgaskets
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 15 Old 06-29-2012, 11:52 AM Thread Starter
is there any tell tale signs that you would see if the head gasket went bad? Truck does not throw the check engine light, never overheats and runs great. I bought a new ford factory cap and will give that a shot. (i did however take truck to ford about 6 months ago for same issue, they compression checked it and it came back normal...)
post #4 of 15 Old 06-29-2012, 11:56 AM
Powerstroke Techie
justinmix's Avatar
No, you won't really have any signs or symptoms unless it pushes out a lot of coolant and then it will start overheating.
I agree with it's probably head gaskets. We blew the head gaskets out of the shop truck towing with the 160 H&S tune.
Best way to tell if it's head gaskets is rig up a pressure gauge in the coolant system. Go for a hard road test and see how much pressure it's building. Most likely under a hard pull you'll see it build up to 16 psi rather quick, especially with that tune. If you see that then it's head gaskets. Putting it back to stock probably won't make it push out as bad but you'll still need to replace the head gaskets soon.
justinmix is offline
post #5 of 15 Old 06-30-2012, 08:32 AM Thread Starter
what kind of price am i looking at to replace the head gaskets? Truck is out of warranty but im thinking of buying a extended warranty because of the issues these trucks have.
post #6 of 15 Old 06-30-2012, 10:58 AM
lhsnbsaoa's Avatar
Garage
Subscribed
Sent from the mower shop
1996 F350 Dually Centurion
Previous trucks: 2003 F-250, 1997 F-350 CCLB, 2000 F-350 CCLB, 2008 F-250 CCLB
lhsnbsaoa is offline
post #7 of 15 Old 07-01-2012, 05:19 PM
Subscribed.
KPBJJ is offline
post #8 of 15 Old 07-19-2012, 05:51 PM
My dealer quoted me $3000 for labor to do head gaskets.
KPBJJ is offline
post #9 of 15 Old 07-19-2012, 08:12 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Stay far away from the aftermarket extended warranties. They love to take your money and will say just about anything to make you feel good with your purchase but when it comes time to need them they will tell you it was a pre-existing problem and that they won't cover the repair. Thats after they tell you to "authorize" the shop to rip it down to figure out what the problem is so that not only will you be screwed that they won't pay for repairs but that you now have a bill with the shop that ripped it down and to get your truck back you have to either fork up the dough for them to repair it or what it cost in labor to rip it down before you get your vehicle back. Trust me they are no good. I have dealt with them once before and never again.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #10 of 15 Old 07-19-2012, 08:18 PM
Wouldn't they need to prove somehow that it was a preexisting problem to not cover it?
KPBJJ is offline
