08 F350 6.4 problems
I have a 08 6.4 F350 and the other day I was driving it and went out to pass someone and it wouldnt go into passing gear properly and would puff whit smoke out the tail pipes. It did it twice and then has not happened since....I have a DPF delete and a edge tuner on it...HELP!!!!
no i havent but ill check it
could also be Edge related
very intermittent problem? there is an updated charge air cooler for this problem.
I hate to post useless info but i have to agree
can u just unplug the EGR....my 04 6.0L that all I did and the thing has not had a problem since?And what do you mean a updated charge air cooler for this problem. ??
No you can't unplug the egr with the edge tuner. I ran the same tuner for a long time with no issues. The white smoke out the exhaust seems to be most common for an egr issue.
ok thanks...anymore options that I could do or should I do the EGR delete?
can u just clean the egr or should you just do the delete
