F450 Broken Oil Dip Stick
Broke off the oil dip stick and can't get the dip stick tube off to get stick out. Any help would be appreciated.
if youre talking bout the yellow handle then ive done that when i slipped tightening the fuel filter cap. there was a little piece of yellow plastic left attached to the dipstick inside the tube. i reattached the ring handle using superglue and pulled it out. tried not to use to much so it wouldnt seep out the sides and adhere to the tube. when i was pulling out the handle broke off again but i had enough of it out to pull out the rest. bought a new dipstick before doing all this.
are you asking about how to get the actual tube out? i believe its heald down by an 8 mm bolt into the upper oil pan. and after you the that out yank like heck. try to find leverage. it is not easy to get out. that o ring likes to stay in there.
