Advice please!! Coolant
Ok guys just got the truck back... Arp studs, gaskets, egr delete with elbow, etc. the mechanic flush my coolant system 5 times... And since i have had it back i have had to add coolant 3 times... Its not puking so What do i do???
I had to top mine up a couple times after my egr delete due to to coolant loss during the removal of the coolers. How much have you added?
could just be air pockets working their way out
Ive added around a gallon
If it is not leaking this just goes to show why it is so important to fill these motors with an airlift tool. That would prevent air pockets from forming and causing this kind of problem.
As far as i know its not leaking no puddles anywhere. And the front cover is fine
Just kinda wryed becuz idk where its going
Well had to add more coolant today... Still not a clue as to y there isnt a puddle under my truck...
Well guys the radiator was leaking... Put a new radiator and guess what... Still adding coolant!!!! What the hell???
Keep tabs on how much total coolant you have put in. If you put in more than about 4.5 gal, than you have a leak somewhere still, or you are burning it. You mentioned you just did HG's and studs? Are they seated right? Do you notice any white smoke from the exhaust?
