Engine quit and wont restart
sunday nite while towing my nephews chevy 1500 back from Reno I was climbing a moderate grade in the Sierras. Everything was smooth and fine.
The engine went into regen. A few seconds later the yellow engine icon came on. 2 seconds later a warning said to get off the road safely now. 2 seconds later the engine died. Managed to get into the only turnout in two miles. After stopping the engine did not even attempt to start. Not even a solonoid click. I had it towed home. (10000 miles out of warenty) bought a code reader and drew codes P200E (cat system overtemp bank 1) and P242D (exhaust gas temp sensor circuit high- bank 1 sensor 3) Still does not try to start. Battery is 13.6 V Any ideas on where to start? |
Thanks Wayne
I am trying to do this without spending a huge amount of money. What are my options. should I try changing this sensor (P242D (exhaust gas temp sensor circuit high- bank 1 sensor 3) But without the engine even trying to run it is pretty difficult to analyze things. Is there a way to effect a reset at home? I did erase the codes and disconnected the battery to reset the computer but it makes no difference. |
replace the last sensor on dpf
Thanks again headed to the dealer to try to get that sensor. I also made a list of every fuse that might affect running and starting. Getting to know my truck better. I have worked on and operated large marine diesels for 30 years, but these black box electronics are a whole new world. Also access is insane with so many things requiring cab off.
I seriously doubt it's a fuse or circuit breaker causing the no-start issue. If the sensor is toast, then it's probably constantly sending the fault indication to the ECM, therefore not allowing the engine to start (still thinks it's in trouble). Luckily this wouldn't be a cab off repair, but I know what you mean. This sensor would be on the exhaust pipe just aft of the DPF...assuming it's the culprit. |
Sensor is first on my list. Thanks.
Well the sensor is changed. For two hours I fought getting the old one out. Was going to use heat on the fitting but Napa Parts guy showed me CRC Freeze Penetrating Solution. Took 6 applications but it worked. Also helped to cut cable and fitting off old sensor in order to use a good box wrench instead of open end. Truck is still not starting. Is there any way to reset at home or do I need to have a dealer reset computer for $170.00. ?
BTW, does the truck even crank? Last edited by cp2146; 04-27-2012 at 08:27 AM. |
