Wierd puking problem?? - Ford Powerstroke Diesel Forum
Old 04-15-2012, 06:03 PM
Truck started puking on me under high amounts of boost 30-40 pounds so i took the tuner out and put the stock exhaust back on the truck and brought it to the dealer... They pressure tested the system while cold and while it was hott held like a champ... So i change the coolant cap and still puking... Any i deas??
Any help is much appreciated guys!!
Old 04-15-2012, 08:30 PM
egr cooler maybe. just a possibility
Old 04-16-2012, 04:21 AM
The tuner i have turns off the egr... But if it was bad wouldnt it have failed the pressure tests??
Old 04-16-2012, 04:53 AM
the tuner only disables the egr valve. exhaust gas still flows through the egr coolers.
depends on how bad the leak is and how long the test was run.
any white smoke out the exhaust?
Old 04-16-2012, 05:27 AM
No white smoke and no leaks just puking under high amounts of boost im so lost man
Old 04-16-2012, 05:41 AM
If it passed the pressure tests the head gaskets should be good right?? Can it still pass the test with a bad egr cooler?
Old 04-16-2012, 05:54 AM
no, its you Head Gaskets. I had the exact same issue. Only puked on high HP tunes running balls to the wall. Took it in they said nothing was wrong. It kept doing it. I finally took it to Rudy's and he did gaskets among other things and no problems since.
Old 04-16-2012, 06:11 AM
Damn i was hoping i could just do the egr delete and make it stop but it looks like ima have to sink some money into this thing
Old 04-16-2012, 06:12 AM
Can i just creep around at low boost for a while until i can save the money? Or will it hurt it
Old 04-16-2012, 06:22 AM
no Rudy told me he drove his for a year before studding it. I would just run it on a lower HP setting and dont do any boosted launches or anything. What tunes are you running?
