6.4 Issues
My truck went into Reduce Engine Power and i had to limp home. I pulled the codes and the only one that shows up is a p2610 ecm/pcm Internal engine off timer performance code and when i cleared it and in about 15 secs it came back on. The book says to pull #36 fuse in engine compartment for about 30 secs and it should clear. When i pulled it the first time it was blown so i replaced it and the code keeps coming back but the fuse has not blown again however the check engine light comes on now but after clearing the code it does drive down the road but seems sluggish a little. Does anyone know what this code is and how to fix the issue with it. Thanks, Frankie
Clear the codes change the oil, filters and fuel filters, wash it and then drive it straight into a brick wall...... or a dealership to trade it in and resolve your high stress levels from dealing with the BSTRD because of all the bs codes and problems related to the DPF... I have finally decided I HATE my 08 F-250 6.4L (6.4Loser) 65,540 oil leaks, DPF replaced, Rear Pinion seal replaced twice with in 16 months, EGR valve replaced, causing the turbos to shut down, tranny leaks, oh did i mention oil leaks, 6 trips to fix the same oil leak caused by one flippin oil change @ FORD!! go figure...and now today my truck tells me after i let it warm up that "Engine Performance Has Been Reduced" wrench on display, "Drive to Clean Exhaust Filter" I drive 10 miles then it goes into Regen, Floored just to hit 60mph, the Cruise control wont turn on, drive 30 miles to complete the "Regen" and the check engine light stays on... sorry for the RANT!!!
i use to have to go to the dealership for sensors and little bs dpf things all the time then i said forget the worranty and listened to some wise people on here and deleted the dpf and i have been to the dealership once in the past 2 years and it was for ball joints I use my truck for work and drive it every day..sorry your having such bad luck but ive owned lots of diesel trucks and this 6.4 is the best I have owned to date.....and its a job 1
i love the truck when it runs and drives but god it is such a **** storm when it sits at the dealer longer then i get to drive it |
I knew that would be the issue. Get rid of that giant canister
Too bad. These all seem to be emissions related issues. Except for the oil drip. Mine was doing that too a bit, from the drain plug, but I snugged it a bit more and no more drip.
