chirping or tapping from back of engine - Ford Powerstroke Diesel Forum
Old 03-14-2012, 10:57 AM
I have a 2008 6.4 power stoke that I purchased towards the and of January. I'll change the oral and filter, change the fuel filters, change the air filter, and draiNed the water separator every couple of tanks of fuel. Sunday I heard what I thought was a squeaky belt tensioner but it went away after I drive for a while. today it came back but after checking the engine it seems to be coming from the rear rather than the front of the engine. I'm supposed to leave tomorrow on a 500 mile tripe in this truck! any input is appreciated.
Old 03-14-2012, 11:02 AM
correction on the above post I've change the oil not oral. Siri typing again.
also the truck is bone stock with 190,000 miles on it. I put about 5500 on it since I got it in January
Old 03-14-2012, 11:11 AM
BTW, Engine is stock with no mods and dpf in place. I did have the latest update for the computer uploaded from the dealer last month.
Old 03-14-2012, 11:12 AM
If its coming from the back of the motor it could be a leaking up pipe. Check for soot on the firewall.
On a side note thats a good amount of miles.
Old 03-14-2012, 01:57 PM
Took it by a shop and it seems to be the lower belt tensioner. They are going to replace it tonight and hopefully the problem will be solved..
Sent from my Autoguide iPad app
Old 03-14-2012, 02:16 PM
Feedback Score: 5 reviews
Originally Posted by Johnsabine2003 View Post
correction on the above post I've change the oil not oral. Siri typing again. also the truck is bone stock with 190,000 miles on it. I put about 5500 on it since I got it in January
Dirty Minded Siri...
Old 03-15-2012, 07:43 AM
mechanic replace the belt tension or this morning put everything back on and it still makes the same noise. It really sounds like a squeaking belt tension or but it's coming from the backside of the motor. was supposed to leave this morning but haven't left yet. Really need some input on this
Old 03-15-2012, 07:52 AM
Old 03-15-2012, 07:53 AM
how can I tell if it's the up pipe? other than the soot? if it is will it kill it to take it on this trip?
Old 03-15-2012, 08:16 AM
Check this thread - Specifically Post #84 (post #s are in the blue header bar above each post on the right). See if that describes what you're hearing.
Who has "the tick"?
IF IT IS, according to this, it's normal.
