6.4 occasionally dies at idle - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-11-2012, 06:57 PM Thread Starter
mo powerstroker's Avatar
Have an 09 6.4 has about 30,000 miles dpf cat delete sct tuner. Truck runs good when driving no loss of power but once and a while when you come to a stop it will die service wrench comes on then it wont just start write up you have to cycle the ignition 3 or 4 times then crank it and it will fire up and drive fine service tool will stay on for a while then goes off. I assumed it is not the fuel filters since it has good power when driving. Anyone ever had this problem?
not really wanting to return to stock so i can take it to dealer if i could possibly fix the problem.
mo powerstroker is offline
post #2 of 4 Old 12-26-2012, 07:25 AM
Same problem
I have developed the same issue!!! What did you find to be the problem with yours?
Randomstuff208 is offline
post #3 of 4 Old 12-27-2012, 06:54 AM Thread Starter
well it did it off and on for months and finally found out it was the in line fuel pump under the cab dealer replaced it under warranty.
post #4 of 4 Old 05-15-2013, 12:48 AM
has it done it since you replaced the pump?
undesputedking is offline
