Oil blowing out of coolant bottle?? - Ford Powerstroke Diesel Forum
Old 03-10-2012, 07:49 AM
Guys I need help.. The truck had been running maybe 10 min. Driving about 50mph the oil light came on and the motor started squeaking bad! I pulled over and shut it off and there was oil all over my drivers side. Oil was blowing out of the coolant bottle like crazy and there is no oil in the motor now. ??? All happend in about 20 seconds. Help!?
Old 03-10-2012, 10:52 AM
Anyone?
Old 03-10-2012, 10:53 AM
No idea. But does NOT sound good.
Basically, wherever the oil is right next to the coolant, that's the spot that I would think failed. Since the oil pressure is higher, if forced it's way into the coolant system.
Don't even crank it over, I'm sure you know.
Old 03-10-2012, 11:29 AM
Yes sir that is what i am thinking.. No I imediatly shut it down and no cranking till its fixed.
Old 03-11-2012, 09:09 AM
Bump bump..
Old 03-11-2012, 10:18 PM
<<< 6.4 Powersmoke
Sounds like the oil cooler took a chit on you! Sorry about the issues, hopefully you didn't damage the engine internally!
Old 03-12-2012, 05:38 AM
My guess would also be a ruptured oil cooler.
Old 03-13-2012, 03:55 PM
Dang.. Does that mean I remove the cab or is it possible not to for a very skilled mechanic?
Old 03-14-2012, 03:47 AM
you can do it cab on, but it's not fun.
Old 03-18-2012, 07:05 AM
If you got oil in the water resevoir then check your engine to see if you got water in it. It may be that the front cover as cavitated and is spilling over into the water cooler. I had this happen to me and thats what it was. Just an Idea:::::
