bellowing white smoke and surging/citting out at idle - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-29-2012, 05:43 PM Thread Starter
i'm working on it is a 08 start it up and it is fine for a couple mins then begins to surge or cut out rpms jump up and down at the same time it starts blowing tons of white colored smoke thought it was egr cooler so dropped 500 and bought a cooler and installed itsame thing any ideas and way to test to be certin i cant aford to keep throwing parts
any input would help
jscho302 is offline
post #2 of 16 Old 02-29-2012, 05:47 PM Thread Starter
also there is a code for 1 and 8 injector contrubution 1 was replaced by previous person working on truck still acts exactly the same
jscho302 is offline
post #3 of 16 Old 02-29-2012, 10:28 PM
Keychain444's Avatar
Take the Dip stick out while the truck is running and see if you are blowing any air/smoke out of the dipstick tube that should tell you weather or not you have a piston issue.
08 F-350 King Ranch, 20" XD Hoss, 33" Cooper Zeon, 5" Turbo Back to 7" tip, WOP Waste Gate, EGR Delete, H&S XRT Pro, S&B Intake..........
Keychain444 is offline
post #4 of 16 Old 03-12-2012, 10:46 PM
merickson's Avatar
You could also take off your oil filler cap with engine running and see how much pressure is in there, should be none to very little.
merickson is offline
post #5 of 16 Old 03-13-2012, 06:11 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
actually 6.4's are known to have more blow by than most.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 16 Old 04-02-2012, 09:56 PM
lurch241's Avatar
hey i had the same kind of problem started the truck let it warm up for a min and it started to act all stupid surging and pouring white smoke took it to ford (since i still have a warrenty) and 3 weeks later got my truck back with a new short block guess the egr cooler failed on the last guy that owned the truck 2 weeks before i bought it hope this helps
lurch241 is offline
post #7 of 16 Old 04-16-2012, 09:03 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
Hey bud. Can you elaborate more on this for me? I just did my EGR delete this weekend and opened up the dip stick, and BAM white smoke coming out of the exhaust while idling. Should I be concerned? Truck runs/ran great after the delete, drove it hard (80+mph) after the delete for a little over 200 miles--engine-oil/coolant temps ran 210EOT/201ECT respectively. (not bad IMHO)
I googled it and found these threads; some say it's normal...others say it's bad o-rings and pistons. If i remember correctly, I NEVER saw any blowby when I would check. Would it have anything to do with the delete?
I'm runnig Rotella T6 and Lucas Synthetic additive (powerstroke specific...not the heavy crap)...would that be a problem?
I'm absolutely stumped here. Thanks in advance.
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #8 of 16 Old 04-16-2012, 09:10 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Erick from PTP and others have said that 6.4's have more blow by even brand new. I personally wouldnt worry about it especially if the truck is running good. I also use T6 but i dont use the additive. I dont have white smoke coming out the exhaust tho. Does it use coolant? How long does the white smoke last?
08 F350 cc/sb 4X4
post #9 of 16 Old 04-16-2012, 09:36 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
No white smoke out the exhaust; truck running like a champ. I tend to be over-anal about my truck but because I've never seen this before, it worries me.
I installed the kit from PTP--great kit minus not including the new exhaust manifold bolts. FML. I didn't have any spacers, nor a second vehicle to go buy some, so I had to use 5 washers instead. Hope she holds!!!!
What kind of temps do you see out of your truck during the summer? I guess I should give Eric a call. He should know best...as always, thanks in advance.
*NEW:
NL Fab:
---Stage 1 Intake
---------CCV Mod
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
wilsonw2 is offline
post #10 of 16 Old 04-16-2012, 09:39 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I wouldnt worry about it. I dont think you will have any problems. My ECT runs about 192-195 and the oil temp about 2-4 degrees higher than that.
08 F350 cc/sb 4X4
