2008 6.4 "TRIPLE PLAY" knock, smoke, boost - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-16-2012, 01:38 AM Thread Starter
Hi all - Sorry this is long - but wanted to give all the info I could up front. Looking for input from others who may have experienced what I did tonight. Truck details - I bought it new so no surprises by what a previous owner could have done. I have the S&B cold air, MBRP filter back 5" exhaust and the Edge w/attitude tuner installed - truck has just under 58k - DPF regen kicked in on the way to a job - completed regen - as always - I get the P2002 (particulate below blah blah) trip to job was about 40 miles of freeway @ 75mph. Tuck totally cooled down - 4 hr job & I'ts not real warm in Minnesota this time of the year - so now the fun stuff, I am less than 4 miles from home, truck is totally warmed, all is good - then out of the blue I got a knock that sounded like a big block gas motor was launching a rod through the block - I let off the gas....the stepped on it again (no load/trailer) If you were behind me, you would have thought you were at the dragstrip behind a top fuel funny car doing a burnout! then loss of power, NO boost from turbo. I pulled over, quick ran codes, and shut it down - Got the P2002, and one about fuel rail pressure too low. It's about 1:00 in the morning - real dark so I couldn't tell the color of the smoke, but it was so thick, i couldn't see the streetlights/stop light or commercial building signs less than a 1/4 mile away. I found NO fuel leak, NO oil leak, NO antifreeze leak. BUT I did find my exhaust "dripping" with liquid...took a white paper towel and wiped inside the exhaust lots of light green FUEL. Restarted truck - NO CODES!! - shut it back off walked around looking for anything else - crawled up into the engine compartment with my Ryobi 18volt spot light looking for anything wet - nothing - decided to have girlfriend bring my F150 down and tow it home - when she arrived said the heck with it, I'll try to drive it - let it break Ford can fix the issue - no issue @ 1500rpm - above that I would start getting the knock again, so I took it easy until I was a block from my driveway - turned the Edge to stock - then floored it - real loud knock again, and heavy smoke, and NO boost - @ 3500rpm digital gauge read 4lbs!! - Oil is NOT overfull - Antifreeze is low - truck is parked!
My son is a Ford Tech(14yrs)- and the dealer knows what mods I have, already had the motor pulled, or should I say the body removed to fix that. Have had the EGR redone, the computer flashes (tech's all know to pull my Edge) I did purchase the extended 200k warranty - but this is still under the 100k - So if you have any idea's please let me know
Brian
2008 F350 Superduty 6.4L 4x4
2008 F150 FX4 5.4L 4x4
1999 F350 Superduty 7.3 4x4
1999 F350 Superduty 7.3 Dually
1992 F250 Supercab
1934 Ford PU - chop/chanel & BLOWN!!
Handyduder is offline
