S10 problems need quick advise(i know it not a ford,lol)just need help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-08-2012, 03:19 PM Thread Starter
My 1992 s10. fuel pump wont turn off even when the key is off..only way to turn it off is to pull the fuze. idc about fixing it, its my beater. just wanna see if there is a problem with using it this way? i dont mind pulling the fuze and puting it back.but will my pump burn up ? or use more gas? thanks for the help guys.
Ericr712 is offline
post #2 of 2 Old 02-09-2012, 05:10 AM
Sounds like either your ignition switch or fuel pump relay failed. Fuel pumps run constantly while the vehicle is running so there is no harm in using the fuse to turn it off and on other than you may be considered a hillbilly.
2008 6.4 CCSB 6 Speed
MODS:
- SCT Livewire
- DOC/DPF Delete
Heavy Smoker is offline
