High Pressure Fuel Pump Shuts Down Engine? - Ford Powerstroke Diesel Forum
post #1 of 37 Old 11-21-2011, 12:36 PM Thread Starter
I have a 2010 F350 6.4 Liter Diesel Super Duty. Fuel pump shut down two weeks ago stranding me on the highway. Truck has been at the Dealer since then. Dealer and Ford says, "contaminated fuel". Insurance Company is investigating. $9,500.00 to do repairs. Not my first diesel, I've had several over the years starting with the 7.3 liter. Any ideas????? Seems hopeless at the moment. 48,000 miles on the truck. Maintained at the dealer routinely. Dealer says metal shavings in fuel tank, fuel lines and injectors.
tnranchero is offline
post #2 of 37 Old 11-21-2011, 05:08 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
The metal would be from the high pressure fuel pump. When water is ingested it causes the pump to fail internally due to a lack of lubrication. The pump then sends the metal shavings through the entire high side and low return side of the fuel system. The last one I did stuck injectors open and kept trying to hydrolock on fuel
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 37 Old 11-22-2011, 05:10 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Do you think an airdog will help the HPFP live a long life?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 37 Old 11-22-2011, 06:57 AM Thread Starter
ok. I take it you are a diesel tech? Work for a Ford House? My insurance is only looking at "current fuel" in the tank and testing that. Does Ford have any engineer's reports or anything I can use to go back to the Insurance for my policy claim?
post #5 of 37 Old 11-22-2011, 06:58 AM Thread Starter
ok, I take it you are a diesel tech? Work for a Ford House? My insurance is only looking at "current fuel" in the tank and testing that. Does Ford have any engineer's reports or anything I can use to go back to the Insurance for my policy claim?
post #6 of 37 Old 11-22-2011, 11:12 AM
Ask your dealer for a copy of the water in fuel/ non warrantable job aid, this has pictures and descriptions of water contaminated fuel systems, your insurance company will usually come inspect and take pictures and this will give them a reference. It may be a good idea to take pictures yourself also. It depends on the company but sometimes they will cover this even if there is currently no water in the tank.
Performance Machine & MFG.
Product Engineer & Tech Support
Brad@PMM is offline
post #7 of 37 Old 11-22-2011, 12:26 PM Thread Starter
can you send me a picture of what you have experienced and possiblly an explanation? I looked at the pump, the service tech pointed out "pitting" but they are barely discernable, going to cost me $10,071.00 to repair now. Insurance agent does not look like they are going to take care of unless they find water in this fuel sample. unfortunate but having to get with attorney now.
post #8 of 37 Old 11-22-2011, 05:27 PM
hit the nail on the head. ive seen this same thing before. its part of the basic diesel diag sheets, "fuel system debris check" and if you answer yes to the question you get a new pump, fuel rail, injectors and you get to flush all the lines
KmC86 is offline
post #9 of 37 Old 11-22-2011, 05:41 PM
Fred@PMM's Avatar
It will not help in a case where mass amounts of water has been put in the tank. Best thing is for everyone to keep an eye out on there WIF light and periodically drain the separator say every oil change. When a situation like this occurs it is not your typical water in fuel condition from condesation it is more than likely a in-ground tank is not sealed properly and allowing water in. Hope this helps.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
Fred@PMM is offline
post #10 of 37 Old 11-23-2011, 05:21 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Good deal, thanks
08 F350 cc/sb 4X4
