TRUCK DIED - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-06-2011, 04:30 AM Thread Starter
TRUCK DIED
OK, after cleaning out my fuel Sep. i put it back together. fairly easy, no leaks, So i decided to take it to work, At lunch there was puddle of diesel about where the Sep. is. and it was dripping, I cranked it up and it stopped leaking, OK no problem i'll get a gasket on my way home, Well Before i could get out of town it died at the light, fuel drain from sep. SO now i'm getting the New gasket, on my way home today. But why did it quit running like that AIR in lines? it was running good b4 that. ANd what do i have to do to get it back on the road again? ? change gasket and???? prime the system? I'm hoping after the gasket install it primes up doing the 30 sec. on thing (6) times, What else??
D.N.S.
08 250 3" Lift
Diamond eye 4" Down-pipe back
No Limit Fab CAI
No Limit Fab. Egr Delete
35" nitto's
H&S Mini
RichardT is offline
post #2 of 3 Old 05-06-2011, 11:23 AM
Quoted: 2 Post(s)
sounds like some of the fuel came out of the lines between the engine filter and the sperator.. and it just wasn't primed.. i would install the new parts your getting.. prime it.. and it should be good.. if its still dies.. might be another small problem you might be overlooking.. doesn't sound like anything major
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 3 Old 05-07-2011, 05:10 AM Thread Starter
Got it going but now my check engine light stays on sounds and runs alright but the light comes on as soon as I turn the key on and stays on manual says emissions not sure I may try disconnecting the batts and c what happens in the mean time it will be limited use thanks to my good ole 7.3 Maybe old but very reliable
D.N.S.
08 250 3" Lift
No Limit Fab CAI
35" nitto's
H&S Mini
RichardT is offline
