please help, tell me it`s not HG ! - Ford Powerstroke Diesel Forum
Old 04-18-2011, 08:41 AM
f450 2008 6.4 w/dpf-cat delete pipe . sct tune (innovative diesel)
had white smoke, rough idle ...and coolant loss
first tought.... egr cooler or water in cac
whcih i confirmed...cac tube removed +/- 2 cup of water !
* still coolant loss ?
so i ordered EGR delete kit from mkm custom(sinister)
installed everything (finger cross)
idle still the same/ NO white smoke...BUT STILL LOSE COOLANT
... SO I DROP oil again... (since i have coolant in oil)
and i put air pressure (+/- 12 lbs) on the coolant reservoir / reservoir full of water ......
and guess what..... got coolant coming out of the oil pan drain plug !
anyone can give me advice or good news ?!?!
steve laliberte
ps: sorry my bad english ! french canadian eh !
Old 04-18-2011, 12:12 PM
Blown headgasket?? What's the mileage and check engine code?
Old 04-18-2011, 01:06 PM
97000 miles
no code
on the road...truck got normal power...no more white smoke
Old 04-18-2011, 05:26 PM
<<< 6.4 Powersmoke
Cavitation of the front cover behind the water pump. Pull the pump and check it out.
Old 04-18-2011, 06:39 PM
hey, i just pulled the water pump out...there is wear/cavitation on the bottom of water pump housing, BUT cant see anything wrong on the back side of the front cover..and gasket look perfect....
Old 04-21-2011, 11:38 AM
sounds like a blown head gasket to me.
Old 04-21-2011, 12:18 PM
what tune have you had the SCT up to? those 6.4L are not really known for blowing headgaskets, but its startin to sound like you may be running into that...
Old 04-21-2011, 04:41 PM
Is that a hole in the bottom right?
