Truck shut down driving across parking lot
Anyone ever seen this....I have an '08 f250 6.4L with SCT/dpf delete kit. Never had any issues until the truck just shut off going across the parking lot. It cranks like crazy, but will not start. Rpms rise a little while cranking, but nothing else happens. SCT did not detect any codes so I got another code reader and checked it again. The results were as follows
P0101 - Mass or Vol Air flow A Circuit range/Perf P179A - Can ECM / Turbo Boost ctrl A Act Circuit Malf P0670 - Glow Plug Module ctrl 1 ckt P0091 - Fuel pressure regulator 1 ctrl ckt low P0003 - Fuel Volume regulator 1 ctrl ckt low P0684 - Glow Plug ctrl module to pcm rng/perf When I clear the codes...2 still remain : P0101, P179A After I try to start again... all 6 codes show again. I already worked with SCT on the phone to try a recovery file and tried other standard tunes. They think everything is ok with the tunes/tuner. Fuses are ok as far as I can tell. Since these two codes are always present I assume they are related to the problem. Probably the P179A code. P0101 - Mass or Vol Air flow A Circuit range/Perf P179A - Can ECM / Turbo Boost ctrl A Act Circuit Malf. If any of you have seen this, or know what these two codes mean, please let me know what was causing it or how it was fixed...Any ideas would be appreciated. Thanks for your help Last edited by blackmac; 04-17-2011 at 07:29 PM. Reason: sp? |
Make sure you checked your fuses in the engine compartment under the vacuum pump. 08 are common place to chaffe the hpfp harness and pop the fuse causing a no start.
