Excessive coolant usage and no smoke - help needed - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-10-2011, 05:37 PM Thread Starter
clys's Avatar
Hey guys, this truck is really perplexing me. It came in for lack of cabin heat and coolant consumption+overheating engine. The trigger got pulled too early and I replaced the headgaskets and studded it. It's back now and the coolant level drops about a litre per hour of idling. There is NO smoke and the tailpipes are dry (DPF delete done as well). I simply cannot understand how a truck goes through this much coolant with no external leaks whatsoever and no smoke. It's an 06/07 build date 6.4. If anyone's seen this or has any tips/pointers let me know, this thing is killing me.
clys is offline
post #2 of 10 Old 02-11-2011, 07:36 PM
RobertS450's Avatar
Quoted: 14 Post(s)
is the heater cores in the cabs on these or outside? My dodges was inside and could leak coolent into the cab
Robert
2010 F450 CC LB 4x4 Black.
RobertS450 is offline
post #3 of 10 Old 02-11-2011, 07:49 PM
Dually Dog
Stanley F350's Avatar
do you have notice of coolant around the clear tank? do you have an egr delete? could be coming from the egr coolers. it has to be going somewhere does it have a grayish smoke coming from the exhaust?
F350 Dually:
Afe stage 2 si cai
Spartan w/ all TCM tunes running 300 daily
MBRP 6" mitre cut dual Stacks
afe 4" down pipe DPF/CAT Delete
egr delete w/wastegate
Elite Studs
I/C Pipe
BOV
Banks Intercooler
SSBC 6 Piston Front Rotors
SSBE rear rotors
Strobe Lights front and rear
Retractable Side Steps
Ram Hood,
Nathan K3LA's Train Horns w/Black 8.5 Gallon 8 Port Air Tank and Air Zenith Dual OB2 Air Compressors
Stanley F350 is offline
post #4 of 10 Old 02-12-2011, 04:42 PM
wired1's Avatar
i would say egr or cavitation in the front cover from water pump, check the oil.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #5 of 10 Old 02-12-2011, 05:32 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
cavitated front cover. how is your oil level?
if you find a front cover gone out it might be wise to put an oil cooler in it. all that aluminum has gone somewhere
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #6 of 10 Old 10-21-2011, 06:37 PM Thread Starter
clys's Avatar
Sorry it took so long to reply. The front cover had eroded badly, leaking coolant into the oil, right by the cam cavity.
New front cover and all is well, common issue I now know!
clys is offline
post #7 of 10 Old 10-24-2011, 06:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
How hard is the front cover to replace? How much did it cost? I wonder if there is a way to solve this problem...
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 10 Old 10-24-2011, 07:00 AM Thread Starter
clys's Avatar
Took about an hour with the cab off. I'd say 6 hours should be plenty with can on though.
clys is offline
post #9 of 10 Old 10-26-2011, 06:13 PM
Send a message via AIM to PowerstrokeTech82787
Theyre not too bad, just pull the radiator etc out of the way, you dont need to suck the a/c down i bend the condenser out of the way so i can sit on the front bumper and from there i remove the fan and hub, the plastic hose that runs up top thats brittle be careful with it because its a PITA to change, i remove the vertical egr cooler, i inspect the coolers at this time to make sure all is well, and then the rest is the 10mm bolts pull the crank pulley i remove the oil pump its easier to remove and i lightly push the plastic coolant hose up slightly and walk the bottom of the front cover off then pull the top slowly until its free. Then i clean the face of the block with brake clean, rags, and a plastic wiz wheel.
I too have been wondering what causes it. This summer no lie I did at least 3 or 4 front covers/radiators water pumps and updated hoses with doubled O rings a day. Id guess its either poor quality in materials for the cover (when they look like a 12ga with 00 shot hit it id say poor quality in material), and hyper extended thermostats. The thermostat housing in a few were gone theres 2 prongs that the T stats "twist" into that were missing and the thermostats were just sitting at the bottom of the T stat housing. When they look bad, just like Sinner said replace the oil cooler because thats where the debris end up.
PowerstrokeTech82787 is offline
post #10 of 10 Old 10-27-2011, 05:30 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Hey your back! Thanks for the info
08 F350 cc/sb 4X4
